Painting T1 11 Plywood Siding - Painting - DIY Chatroom Home Improvement Forum
Old 09-28-2009, 12:23 AM   #1
painting T1 11 plywood siding
does anyone have trick for painting T1-11 siding, I am using Brush for grooves, and roller for the flat face of siding, It is REALLLY a hassle and very time consuming to switch between the 2, I wish there was a roller to cover it all in one move. All suffestions are apriciated. Thanks
vstar is offline   Reply With Quote
Old 09-28-2009, 06:15 AM   #2
the Musigician
DangerMouse's Avatar
spray it on, or brush grooves first, then roll.
DM
Old 09-28-2009, 06:26 AM   #3
Remodeler
MinConst's Avatar
You can try a pad. I remember painting a house full of T1-11 and tried several types. Ended up with the pad as it seemed to be the best. Nothing was great. Spraying has got to be the best way to go.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 09-28-2009, 06:32 AM   #4
1" or 1 1/4" roller nap. Keep roller nap very wet.
mark942 is offline   Reply With Quote
Old 09-28-2009, 01:34 PM   #5
Too Short? Cut it Again!
Ditto this advice
Old 09-28-2009, 05:26 PM   #6
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Spraying would be the most efficent method of application. Otherwise use a a 9 or 18 inch roller with a 3/4 inch nap and brush the grooves.
housepaintingny is offline   Reply With Quote
Vinyl Siding Versus Painting Asbestos freedom_fighter Remodeling 3 02-27-2009 10:35 PM
Rotten plywood under siding thisolddump Building & Construction 8 05-12-2006 09:43 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
