Painting Stucco Exterior A No No? - Painting - DIY Chatroom Home Improvement Forum
Old 06-17-2008, 05:42 PM   #1
Painting stucco exterior a no no?
I have planned on painting my stucco house since I bought it but then someone told me that you should never paint stucco, that doing so will trap water in between my walls and exterior and turn it to mush? Is this true? Do I have any options for painting or am I stuck? Thanks!
Corcoran1 is offline   Reply With Quote
Old 06-17-2008, 08:09 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
What?
Stucco...like that textured stuff on all the houses in Florida?
Of course you can paint it!
slickshift is offline   Reply With Quote
Old 06-17-2008, 08:13 PM   #3
Remodeler
MinConst's Avatar
There all painted here in Florida.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 06-19-2008, 04:28 PM   #4
OK, I assumed they could be but then someone told me you can't. Then I googled and found other people saying it shouldn't be done, so I got a little worried.
Old 06-19-2008, 07:35 PM   #5
slickshift's Avatar
Tonight On DIY Chatroom
Google:
Friend Or Foe?
You decide...tonight on DIY Chatroom
Old 06-20-2008, 07:00 AM   #6
Stucco has been painted for years and years.Last few houses I painted w/stucco I used a Elastomeric product. The only problem with it is that you can not stop in the middle of a wall section,or a gable section.The colors are a tough go to keep matching.Each batch (even boxing) is different.
Good Luck.
mark942 is offline   Reply With Quote
Old 06-20-2008, 09:00 AM   #7
Shouldn't be a problem to paint stucco. I've painted a number of houses with stucco here in Winnipeg Canada where we have extreme temperatures (-45 Celsius up to 35 degrees Celsius) and have never had a problem except ... depending on the type of stucco. The smoothed out stuff is easily rollable - just get a medium roller and apply the paint generously. The course or 'deep' stucco is a serious problem. The only way I'd do it is with a sprayer and that will severely limit you to painting when there is absolutely NO wind. I've seen cars and eaves and flower beds completely speckled with paint. So, go ahead and paint your Stucco just bear in mind the previously mentioned variables.
firesoflife is offline   Reply With Quote
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 06:23 PM
couple of q's on stucco exterior joeyboy Building & Construction 7 05-19-2007 10:04 AM
Painting Stucco joe3534 Painting 4 04-07-2007 03:46 AM
Painting Stucco dyad8 Painting 8 12-21-2006 11:01 AM
Stucco leak (long post) Pat B. General DIY Discussions 1 03-24-2006 06:54 PM
