Painting Stucco After Filling A Crack - Painting - DIY Chatroom Home Improvement Forum
Old 03-02-2013, 12:31 PM   #1
Rewards Points: 16
Painting Stucco After Filling a Crack
I filled a fine, horizontal crack in my stucco exterior with clear caulk and allowed it to dry. Now I need to paint over the repair, but my first attempt, using acrylic craft paint, looks really obvious (see attached picture). Any suggestions? Just try again with a better color match? The location is in the entryway and does not get wet. Thanks.
mahoopes is offline   Reply With Quote
Old 03-02-2013, 01:16 PM   #2
DIY staff
Rewards Points: 7,174
I moved this to the painting section for you-----
Old 03-02-2013, 02:30 PM   #3
Mahoopes, you have to be careful caulking stucco. You may have seen stucco ceilings that look like the Amazon River tributary system, that's the result of using caulk. Caulk will have a tendency, even with flat paint over it, to "shine" because of the difference between the "sealed" caulk surface and the porous stucco. For future reference, they sell a knife grade compound for patching stucco.
As to your current situation, that's a bit of a tough call. Firstly yes, try a better match, if you don't have the paint or it's unpainted. The hardness and porosity of a surface will affect color so it may be a difficult thing to match. Do you have any electrical outlets outside that you could remove and chip a piece of the stucco out to take to a real paint store, that would improve your starting point.
Old 03-02-2013, 03:02 PM   #4
Rewards Points: 13,300
Read the tude of the stuff you used.
Does it say paintable?
If it's 100 % silcone it can not be painted.
Old 03-02-2013, 03:27 PM   #5
cdaniels's Avatar
It's not silicone it's got paint on it.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following User Says Thank You to cdaniels For This Useful Post:
jsheridan (03-02-2013)
Old 03-02-2013, 05:45 PM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 234
tube maybe?
Old 03-02-2013, 06:18 PM   #7
Rubbin walls since'79
Brushjockey's Avatar
Sometimes i have 'tude..
And you said you we're using acrylic craft paint.. on an exterior?
Why not use actual exterior paint? If you are just painting the caulk- chances are pretty good they will stand out.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 03-02-2013, 07:42 PM   #8
Rewards Points: 16
Thanks all -- I feel smarter already, though belatedly. I will check the 'tude of the caulk and pray it's not silicon. I only used acrylic paint because I can color match it on-site. I do have an outlet from which i could take a sample to the real paint store, and that's a great tip, thanks. Hope I haven't messed this up irreparably!
Old 03-03-2013, 11:42 AM   #9
Rewards Points: 16
D-oh
D-oh, yes, I used silicon on the stucco crack. Thoughts on the best recovery? I see some referenced online to roughening the silicon and spackling over it . . . .
Old 03-03-2013, 12:21 PM   #10
DIY staff
Use a sharp knife and cut it out-----nothing will stick properly to it---
Gymschu (03-03-2013)
Old 03-04-2013, 11:23 AM   #11
Rewards Points: 16
No can do - it's just a hairline crack, and I smeared the silicone caulk 1/4 inch onto the stucco on each side. On my way to Sherwin Williams to get their paintable silicone caulk. Then will mask it off and clean it as well as possible to remove the acrylic paint, etc. Oy.
Tags
stucco repair help
painting stucco ceiling judy60 Painting 0 05-09-2012 12:48 PM
Painting limestone fireplace janell Painting 2 08-17-2010 06:29 AM
painting stucco sorta myself AdamBNYC Painting 1 08-16-2010 09:17 AM
New + Old Stucco Painting, many questions astarael42 Painting 1 04-03-2010 09:53 PM
Vinyl siding and stucco. PrairieStudent Building & Construction 4 08-29-2008 04:03 PM
