Painting Stone? - Painting - DIY Chatroom Home Improvement Forum
Old 04-26-2013, 10:31 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,834
Painting Stone?
Two questions...have a stone wall that needs to be painted....
1. What is the best primer?
2. Is there a good clear coat to put on top that will prolong life of the paint?
ddawg16 is online now   Reply With Quote
Old 04-26-2013, 10:39 AM   #2
Rewards Points: 626
Why would you want to paint a stone wall? If it is river rock or flag stone painting it will ruin the value of the stone.
Nailbags is offline   Reply With Quote
Old 04-26-2013, 11:17 AM   #3
JOATMON
ddawg16's Avatar
block wall at school....has a mural on it...
Old 04-26-2013, 11:19 AM   #4
Too Short? Cut it Again!
Interior or exterior? And you said stone then concrete block?
Old 04-26-2013, 11:25 AM   #5
JOATMON
ddawg16's Avatar
Imagine your standard cement block wall at a school next to the play ground...
Old 04-26-2013, 11:33 AM   #6
Rubbin walls since'79
Brushjockey's Avatar
Then a masonry primer like SW Loxon will work well.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Gymschu (04-26-2013)
Old 04-26-2013, 11:45 AM   #7
Ditto. Follow with a graffiti resistant coating if needed.
Old 04-26-2013, 01:22 PM   #8
Rewards Points: 626
Cement is way diffrent then rock wall.
The Following User Says Thank You to Nailbags For This Useful Post:
Idea for a clean section break using stone veneer tompace Remodeling 4 04-08-2013 08:08 AM
Real Stone Facing Dilemma ydiy Building & Construction 6 06-26-2011 02:07 PM
Fireplace w/ TV focus point. Stone to ceiling or not? POLL 6fthook Interior Decorating 2 05-25-2011 09:02 PM
What Type of Stone Do I have and What Should I use to Clean It? limitdiy General DIY Discussions 4 04-04-2010 09:04 PM
Painting Exterior Stone?? JKE Painting 4 06-17-2009 09:50 PM
