Old 07-05-2008, 08:38 AM   #1
Painting Steel I-beams For Outside Retaining Wall
Im Building A Soldier And Pile Retaining Wall Using Steel I Beams And I Want To Paint The Steel. The Steel Has Some Light Surface Rust. What Is The Process Of Painting Steel?
lyndon9 is offline   Reply With Quote
Old 07-05-2008, 02:18 PM   #2
Remove the rust (perhaps using a hand grinder with a rotary steel wire brush) and then paint the steel with an OIL BASED primer meant for metals like Rustoleum's metal primers.
Nestor_Kelebay is offline   Reply With Quote
Old 07-05-2008, 05:21 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Remove the rust
Coat with a quality industrial coating, possibly an epoxy or epoxy reinforced, from you local Paint Store
Your local EPA regulations will determine what is available to you
The Big Box Home Centers will not have the best available
Paint Stores and contractor supply places will have the best available
slickshift is offline   Reply With Quote
Old 07-05-2008, 11:55 PM   #4
Slickshift is right. An epoxy paint will provide much greater protection than an alkyd paint.
I was thinking "inside the box" of only oil based and latex paints.
You might also want to consider a "moisture cure polyurethane", which are also generally considered industrial coatings. On of the biggest names in non-yellowing moisture cure polyurethanes is Wasser.
http://www.wassercoatings.com/
Maybe e-mail them and describe your problem, and they'll recommend a suitable product.
But be warned. These products are not inexpensive. You'll be looking at $150+ for a gallon of a moisture cure polyurethane paint. Check with Wasser as to the performance of moisture cure vs. epoxy paints on metal. I suspect one possible advantage the moisture cure might have is that you may be able to reseal the can if you don't use it all so that you can apply a second coat. However, I believe there would be enough humidity absorbed into the paint while it's open that resealing the can might not be feasible anyway. Check with Wasser on that.
Retaining Wall DIY_JC Building & Construction 5 05-21-2008 02:48 PM
retaining wall luv2hunt Landscaping & Lawn Care 1 05-02-2008 08:45 PM
Going to build a retaining wall. Want to run my idea by you guys and gals keyser soze Landscaping & Lawn Care 5 03-17-2008 06:33 PM
How to butt wood stud wall to steel stud wall? Yorkergizer Building & Construction 3 12-01-2007 01:28 AM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 01:02 AM
