Painting Steel Door - Painting - DIY Chatroom Home Improvement Forum
Old 02-11-2009, 11:30 AM   #1
painting steel door
I am needing to paint the interior side of a couple of steel exterior doors. What is the best way to do this.
Do they need primed? special primer of some sort? Or can you just put a latex interior paint over a scuffed surface from the factory, which I assume is primed somewhat anyway.
mbaker76 is offline   Reply With Quote
Old 02-11-2009, 06:33 PM   #2
Man of many hats
wrangler's Avatar
Rewards Points: 354
It should be primered from the factory. If weather and space permits, the easiest way is to remove the hinge pins, lay it on saw horses and then paint it. This will help prevent runs. A good acrylic latex should work fine for your project.
Man of many hats
wrangler is offline   Reply With Quote
Old 02-11-2009, 06:40 PM   #3
Remodeling Contractor
I would only use an oil base on steel doors and spay it on.
Old 02-11-2009, 07:27 PM   #4
I went to a local paint store and they told me to use an alkyd primer then top coat with whatever i wanted which I already have a part gallon of latex from the other interior doors i can use.
OR they said just get a gallon of oil based paint to match and skip the primer.
any thoughts on that?
Old 02-12-2009, 08:52 AM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
I would still prime. That door I am sure will get a lot of abuse so you want the most durable finish you can get and you will get that with a coat of good quality primer.
Old 02-12-2009, 09:39 AM   #6
yeah thats what i figured would be best. But witht he added step ill have to wait until it warms up a little more so i can take the door off without freezing everyone out. No big deal, id rather do it once than come back and do it again when the paint chips off.
Old 02-12-2009, 10:44 AM   #7
DIY Rookie
Send a message via AIM to jpfreak33
Lay it down and spray for best results IMO
jpfreak33 is offline   Reply With Quote
Old 02-12-2009, 05:55 PM   #8
Tired, Cold, and Damp
slickshift's Avatar
For steel, and factory primed (notorious for being "iffy" at best), the best way to finish it is to re-prime with alkyd/oil (still the best for rust prevention) and top-coat with either a solvent-based (alkyd/oil) or waterborne enamel
slickshift is offline   Reply With Quote
steel door sticking in frame bruce_hyman Building & Construction 10 12-20-2008 08:17 AM
Installing steel entry door NoExperience Carpentry 2 10-23-2008 12:23 PM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 04:07 PM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
