Painting Stairwell To 2nd Floor - Painting - DIY Chatroom Home Improvement Forum
Old 10-27-2013, 04:13 PM   #1
bryanp22's Avatar
Rewards Points: 288
Painting stairwell to 2nd floor
What's the best way to paint a stairwell to the second floor? I was considering buying a 26 foot ladder unless someone has a better idea. Currently I have two ladders a 6 foot and a 24 foot extension ladder
bryanp22 is offline   Reply With Quote
Old 10-27-2013, 05:30 PM   #2
Rewards Points: 13,270
An extension ladder will be useless.
Need one like this and an extendable walk board.
http://www.littlegiantladder.com/lit...nt/type-1.html
Costco and Wal-Mart have one that works the same but only cost $99.00.
http://www.shopping.com/werner-werne...feet-long/info
Both can be rented.
Old 10-27-2013, 07:13 PM   #3
cdaniels's Avatar
Depends completely on the shape and size of the stairwell.I have painted dozens with a step and extension.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 10-27-2013, 08:13 PM   #4
Rewards Points: 6,652
If all you are going to be doing, is using this one time, for the cost of that ladder, you may be better off just renting it, or paying a local good painter, to do the work, so that you do not have to spend twice as much time, picking up the ladder, setting up, cleaning up, returning the ladder after you are done.
The only other suggestion, would be maybe use a scaffolding system, and go that route for the job, if it is cheaper then renting the ladder.
Old 10-27-2013, 08:53 PM   #5
ltd
Rewards Points: 536
you really need more info , a picture is a must to help you .with that said ,I can get most all 2 story entrances with a 20 ft. and a little giant ladder
ltd is offline   Reply With Quote
Old 10-28-2013, 09:03 AM   #6
Amateuralex's Avatar
Rewards Points: 270
It's obviously not as good as a platform, but a brush taped to a pole can actually get a lot done with some patience. If you're cheap and don't have easy access to a ladder or scaffold.
Amateuralex is offline   Reply With Quote
Old 10-28-2013, 09:34 AM   #7
bryanp22's Avatar
Rewards Points: 288
My local Home Depot does rent a multi purpose Werner ladder that I think will work. Just going to try and use that I guess
Mid span bridging lylsutherland Building & Construction 2 10-30-2012 12:10 AM
How to repair a concrete floor we just had repaired! timbo59 Flooring 11 01-04-2012 07:15 PM
Painting Concrete Basement Floor techinstructor Painting 1 06-21-2010 07:29 PM
Hardwood floor questions (56K) ukrainetz Flooring 1 08-02-2009 02:08 PM
Hardwood Floor Painting Advice / Tips / Tricks? cherie Flooring 3 09-05-2008 10:52 PM
