#1 |
Painting stairs and railings.
I have painted our stairs before but never the railings.
The railing tops are stained right now the the ballusters are painted white. I have googled how to do it but would love any personal tips before getting this project underway. Did anything work out well or not well for you? I am going to paint the steps white, keep the ballusters white, and stain the blonde handrails an espresso color. After all is done I will install a runner. Thanks! |
#2 |
I have balluster rails on my porch that I paint using a 2.5" angular sash brush. I have always painted one side as complete as I can on the whole assembly, then go around and do the front, wrapping it around to the back. I'm sure a paint pro or two can give better advice on application.
My other suggestion is use an off-white, iven if it is only slight, that will blend with your top rail and room. An untinted white with a dark railing may appear too stark and perhaps less professional, IMHO. |
#3 |
Rubbin walls since'79
Just like any painting over varnish- the secret is in the prep. Scuff sand really well, wipe clean and prime with a good bonding primer.
use a harder paint meant for trim, not a wall paint.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS |
#4 |
Do the handrails, then the ballusters, then the stairs.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| concrete stairs with side walls | daleinpg | Concrete, Stone & Masonry | 3 | 09-21-2012 09:22 AM |
| Painting Metal Stairs | ArlaFP | Painting | 3 | 01-21-2011 10:24 AM |
| Add stairs to cement base | Lexiesmom | Landscaping & Lawn Care | 4 | 11-20-2010 08:06 PM |
| Wire staircase railings | jamiebond | Remodeling | 2 | 11-06-2010 07:57 PM |
| Wrought Iron Railings for Stairs | ThomF | Carpentry | 3 | 11-01-2006 08:04 PM |
