Painting Or Staining A Deck - Painting - DIY Chatroom Home Improvement Forum
Old 07-26-2008, 09:27 PM   #1
Slug
Painting or staining a deck
We are painting or staining the deck of a fixer-upper this summer. The question is which paint or stain? it looks like someone in the past painted? or stained? an area of it. Looks like it was sprayed on judging from the overspray. Probably just one coat as it has worn to bare wood in a lot a places. I've been told I can use a Flood product with out much prep (no sanding) regardless of what is on it now. Any thoughts?
slug is offline   Reply With Quote
Old 07-27-2008, 02:30 AM   #2
Faron79's Avatar
Rewards Points: 260
Think again...
Doesn't matter what product you use...
If the deck is showing that kind of surface, SAND IT DOWN to even wood-tone.
* Rent a flat, vibrating-plate sander that uses 12" x 18" sheets.
* Sand through old coatings & crappy wood.
* NOW, you've got a surface that will ABSORB AND HOLD stains evenly.
THEN...decide if you want a solid-color look; OR the semi-transparent look, where you can see the woodgrain.
Sorry to be so blunt...there's no shortcuts here.
Faron
Faron79 is offline   Reply With Quote
Deck staining nightmare sk8z Painting 14 12-29-2009 06:24 PM
Deck Staining -- compatible primer & stain issue? butterclem Painting 1 03-21-2008 09:21 PM
New deck staining questions sk8z Painting 7 11-14-2007 07:45 PM
Painting my deck Floorwizard Painting 8 09-25-2007 11:32 PM
staining my patio deck Morry Painting 3 07-26-2006 04:37 PM
