Painting Stained Wood To White - Painting - DIY Chatroom Home Improvement Forum
Old 07-29-2011, 11:31 PM   #1
ebaygolfer's Avatar
Painting stained wood to white
Yep..the homeowner wants to paint all the stained interior doors, windows and trim white. It's a big job with lots of prep to do...any tips on the process?
My plan is to sand (lightly) to knock down the sheen, fill holes & cracks, prime with an oil based primer, and top coat with BM Impervo.
Any short cuts out there?
Thanking you in advance for any ideas, tricks of the trade,,,etc.
ebaygolfer is offline   Reply With Quote
Old 07-29-2011, 11:35 PM   #2
ebaygolfer's Avatar
Old 07-29-2011, 11:37 PM   #3
i might wipe it all down with some liquid sand just to make sure. you using the oil or latex impervo? thats what im using all my trim, the impervo. best oil paint ive ever used.
Old 07-30-2011, 04:02 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 396
You got it. Forget the liquid sand, waste of time and $, but be sure you wipe off any dust and clean well before priming.
The Following User Says Thank You to chrisn For This Useful Post:
ebaygolfer (07-30-2011)
Old 07-30-2011, 06:16 AM   #5
Ebaygolfer, I'll second Chrisn, skip the liquid sand. Sorry DannyT. LS has it's uses, but not for this application, IMH(umble)O. However, I would give a good sand prior to priming, even though using a bonding primer. Clear coats have a tendency to mask a few blemishes that paint will not, like drips, sags, and grit. Get a good quality oil primer with good bonding properties, as this is the crucial step to long term success, don't skimp here. Putty and caulk after priming, or you'll find you missed a lot after the white primer highlights all the holes and gaps. I like using lightweight vinyl spackle to fill holes. Overfill the hole and sand smooth on the between prime/first finish coat sanding, then caulk. This job will really take time away from your golf game.
Joe
The Following User Says Thank You to jsheridan For This Useful Post:
Tags
painting , stained wood to white
Painting wood bed frame that has been stained JamesTee Painting 3 03-14-2011 11:32 PM
Painting wood finished trim white... leverne99 Painting 12 06-06-2009 06:31 PM
Painting natural wood windows lauries Interior Decorating 5 04-02-2009 07:07 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
Which paint to use? Painting wood trim white Proulx06 Painting 11 04-09-2008 08:18 PM
