Painting Stained Trim And Doors - Painting - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-12-2011, 09:00 PM   #31
Rewards Points: 590
Well, I started taping up this huge french door and after 20 minutes and only TWO glass panes of one side taped, I thought, "maybe I should just stain this darker to match our dark furniture....". It seems like a fine, solid door.
Can I sand this and stain it? What do I use, a MinWax product?
And most importantly, do I still have to **TAPE** this SOB?
noone is offline   Reply With Quote
Old 08-12-2011, 11:19 PM   #32
Noone, I think you're making a bigger deal out of this than you have to. I have faith that you can paint that door without tape. I have a tutorial on working without tape on my blog, read it. It's geared toward cutting walls but the principle is the same. Then get yourself a quality 1.5 inch angle sash brush. Do all the inside sash first. Then do the outside sash only and feather out the material that overlaps on the stiles and rails. While that's drying, do the heel and toe, wiping any overlap onto the face with a rag. Then come back and do the stiles and rails. (deviation from the norm due to using BIN). On the sash, run a brush full down the center to cover, then take a dip and do each side of the individual muntin. Lap onto the stiles and rails but lay them off in the direction of the grain. Just work your way through one muntin at a time, top to bottom. If you start messing up, go to another section and let the last section dry before you resume. You can do it, put the tape down. And no, you can't stain. You can only stain unsealed wood.
Old 08-13-2011, 12:54 AM   #33
m1951mm's Avatar
If you still choose to use tape after seeing Joe's post, get yourself a wallpaper knife (one of the breakaway blade types), the straights are easy over lap a little bit and then cut away the excess with the knife. Nice crisp clean corners. With the blade cut from the corner out and be careful not to cut the wood.
m1951mm is offline   Reply With Quote
Old 08-13-2011, 04:50 AM   #34
paper hanger and painter
chrisn's Avatar
Rewards Points: 510
It will not hurt to get some paint on the glass. it comes off easily with the tool in the pic, just use a new blade
Old 08-13-2011, 07:17 AM   #35
Rewards Points: 590
Yeah, I'm definitely over thinking things here. I just need to do it and be done with it. I'm dreading getting BIN all over the glass. Seriously, you can't revarnish a previously varnished door a different color?
Old 08-13-2011, 08:59 AM   #36
Noone, work with the tips of the brush. Hold the brush with the tips of your fingers. You're only dipping just the tips of the brush in the paint. And hold the brush lightly. Never death grip the brush. I was taught that a brush and roller should be held so lightly that I can knock them out of your hand. Work with flowing motion, there's no choppiness or stop/start. Put the tip of the brush on the muntin where you want it right up against the glass, lock your wrist, and pull it along that line using the pointers provided. When you're applying paint to the facing edge of the muntin, let the brush roll over onto the side of the muntin which will provide a little extra material that the brush will push up to the line. Relax, take your time and concentrate. Go Noone, Go Noone, Go Noone. LOL
Old 08-13-2011, 09:44 AM   #37
Rewards Points: 590
Yessss!!!! I'm psyched now!!! Be one with the brush young painter apprentice. I can do it. I can do it!!
LOL
Thanks again for the tips. I will post finished pics.
The Following User Says Thank You to noone For This Useful Post:
m1951mm (08-13-2011)
Old 08-13-2011, 11:51 AM   #38
LOL
Yes Grasshopper, find your zen. Tune in to your inner brush.
On a more comical note, I would advise, if one side of that door is always blocked from view, ie, the door is always open, practice on the side that is rarely in view. No shake in confidence there, just good advice that I follow myself.
The Following User Says Thank You to jsheridan For This Useful Post:
Old 08-13-2011, 04:44 PM   #39
chrisn's Avatar
Rewards Points: 510
never mind
Painting Stained woodwork and trim flowergal Painting 2 03-25-2010 10:25 PM
Do Floor Installers Usually NOT Trim Doors? thebigsee Flooring 20 11-22-2009 09:14 AM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 12:16 PM
Trim color and interior doors..white or off white? kristinnsmith Interior Decorating 3 04-22-2008 05:48 PM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 10:16 PM
