Painting With A Spray Gun--any Opinions - Painting - DIY Chatroom Home Improvement Forum
Old 06-18-2009, 07:30 PM   #1
nelsonned's Avatar
painting with a spray gun--any opinions
There's not much choices in the market. So I wont ask about specific brands of paint guns. What I would like to know is if painting with one really worth the trouble of buying a gun/ canister and the compressed air supply. I want ot use for basic projects around the house.
nelsonned is offline   Reply With Quote
Old 06-18-2009, 07:42 PM   #2
the Musigician
DangerMouse's Avatar
i had one once, used it once .... sat for years, gave it away. brush and roller for me.
if i want to spray anything, i use my Binks airbrush and compressor.... Po)
wouldn't advise painting a fence with it though.... lol
DM
Old 06-18-2009, 10:04 PM   #3
Most professional painters use airless sprayers ( no compressor ). I would recommend that you rent one for about $60-$70 for a day to see if it is something you want. I currently have several and they are a godsend. I would not know what to do with-out them. Good Luck
waynech is offline   Reply With Quote
Old 06-19-2009, 11:22 AM   #4
A high pressure paint gun will lose a lot of paint due to overspray. Not really suited for house painting and stuff. If your painting a car then....... If you want to spray a house get an airless as a previoius poster mentions.
Mike in Arkansas is offline   Reply With Quote
Old 06-19-2009, 01:42 PM   #5
Kellster
mjkpainting's Avatar
Rewards Points: 77
I agree, you should rent one and see what you think. Just be sure you do your research on how to use it properly. To operate a sprayer from setup to cleanup is not one of those common sense things. It's pretty complex and I would reccomend you have someone with you that has used one before.
Once you get the hang of it and have a system down an airless sprayer saves a lot of time and if you are a diy'er you probably be really glad you got it.
I can tell you some horror stories of things I have personally done with a sprayer that would blow your mind so you really need to be careful.
mjkpainting is offline   Reply With Quote
Question about spray painting DexterConnector General DIY Discussions 2 05-24-2009 08:40 AM
Spray painting wood siding Martshandle Painting 6 03-29-2009 10:50 AM
Spray painting interior trim to look like glass. sprayer48 Painting 2 04-15-2008 08:15 PM
Spray Painting joe3534 Painting 13 07-02-2007 03:43 AM
