Old 10-03-2012, 04:09 PM   #1
painting a spindle railing
how do I paint a spindle railing? The finish is not worn off but it needs some kind of topcoat. I thought I might steel wool it then maybe use a verathane as a to finish. I am not sure on how to put a finish or what to use.
jsuper is offline   Reply With Quote
Old 10-03-2012, 04:41 PM   #2
An old Tradesmen
Moved to Painting forum.
The Following User Says Thank You to beenthere For This Useful Post:
BigJim (10-03-2012)
Old 10-03-2012, 05:27 PM   #3
sdsester's Avatar
A nice quality angled 2.5 inch sash brush will work nicely. Anything smaller will not hold enough material.
They also sell cutesy mini roller schemes for spindles. I have honestly never used one but I guess they could work.
If you are painting them and they have been stained and varnished? I think a bonding primer would be a good idea.
sdsester is offline   Reply With Quote
Old 10-03-2012, 06:16 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
You said paint, and then said Varathane- which is a clear.
To help us be clear- what is on it now, and what do you want it to be.
Will help us to help you- be clear and detailed.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
sdsester (10-03-2012)
Old 10-03-2012, 06:25 PM   #5
it is stained and all I want to do maybe light sand it and then put some kind of clear sealer. Do you recommend a deaf thane, verathane or what do you suggest
Old 10-03-2012, 06:36 PM   #6
sdsester's Avatar
Nice brush for solvent products and a polyurethane would be what I would reach for first. But you know, if I thought about it, a clear epoxy reinforced acrylic coating might not be a bad idea. It will not yellow.
Ask your real paint store. Or if you are near water? Marine paint suppliers will be up on the latest clear coat products.
Old 10-03-2012, 08:27 PM   #7
I don't know what Sds is talking about- but my fav interior waterborne poly that is strong and easy to use is Zar UltraMax modified alkyd.
Used it today- great stuff- low odor, dries quick.
Some Ace Hdwr stores carry it- some paint stores. Not at HD or Lowes.
Old 10-08-2012, 12:44 PM   #8
Would this ultra max be also good for refinishing kitchen cabinets?
Old 10-08-2012, 04:58 PM   #9
Sure - but remember to clean well. scuff sand- wipe and possibly stain where needed...
Old 10-23-2012, 07:14 PM   #10
Any other places that I can purchaseZar Ultramax? I tried all the Ace hardware stores with no luck. Thanks for your help,Jack
Old 10-23-2012, 07:44 PM   #11
In my area the big box stores do carry ZAR products I'm not sure about this particular one but they may be able to order for you.
Old 10-24-2012, 04:39 AM   #12
paper hanger and painter
chrisn's Avatar
where ever you are ,put your'e zip in the blank
http://www.ugl.com/zarWoodFinishing/...xWoodStain.php
painting a already white wood railing cheryl golosky Interior Decorating 2 04-16-2011 07:29 PM
Painting wooden fence and railing Mikef5000 Painting 19 03-25-2011 08:33 PM
Painting white wooden loft railing Meredith23 Painting 3 02-15-2009 03:17 PM
painting a wood railing monte7 Painting 1 05-27-2008 09:55 PM
