Painting With Snow On The Ground - Painting - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 10:30 PM   #1
painting with snow on the ground
I have painters coming in the morning to paint. The contractor said that it will be 50 degrees outside so there won't be any problems with the paint not sticking to the old wood or masonite.. Really?? There still snow on the ground and what about the wind chill factor. The label on the paint is Proffessional Quailty..I think they are broke and need money. Your call
diana75074 is offline   Reply With Quote
Old 01-13-2011, 12:14 AM   #2
Rewards Points: 526
Wind chill doesn't really affect inanimate objects, so no worries there. However I would be just as concerned with the overnight low and the moisture in the substrate as I would be with the daytime high. Where are you located and what kind of coating product are they using?
Windows is offline   Reply With Quote
Old 01-13-2011, 12:16 AM   #3
Rewards Points: 526
Plano Texas. I just figured it out. Tell your paint crew to come later in the week when it warms up.
Old 01-13-2011, 07:04 AM   #4
Gymschu's Avatar
Rewards Points: 852
Well, I can see you really checked this contractor out thoroughly. ......"looked at the paint label and it said professional quality?" Did you get three quality references? Did you go look at some of their recent work? "I think they are broke and really need the money." If I had a customer like you, Diana, I'm sorry but I would pack up my equipment & never come back. If your level of confidence in this guy and his crew is that low, you have a recipe for disaster in my opinion.
Gymschu is online now   Reply With Quote
Old 01-13-2011, 02:36 PM   #5
Check the surface temperature of the what is being painted If its within specs and there is no moisture on it then it should be OK.
It like painting a deck when its 80 degrees. Its not the air temperature its the surface temperature and if the surface is in directly in the sun and it is 80 degrees out side you can be sure the surface temperature is going to be way over 80 degrees and not ready to be painted.
OneCallJohn is offline   Reply With Quote
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Bonding Ground in Conduit jamiedolan Electrical 5 01-26-2010 10:14 PM
To ground or not to ground, that is the question cartalker Electrical 8 10-18-2008 10:12 AM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
