-   -   Painting a smooth fiberglass door (http://www.diychatroom.com/f4/painting-smooth-fiberglass-door-187817/)
jerome8283 09-29-2013 09:51 PM
Can someone please share recommendations for painting a smooth fiberglass door? Thanks
747 09-29-2013 10:39 PM
Clean it. Then hit it with fine grade sand paper. Wipe off. Then SW exterior superpaint or BM exterior regal select.
If its not preprimed i would go with XIM UMA Its a primer sealer. Really good stuff.
jerome8283 09-30-2013 10:30 PM
Thanks. No Primer? SW makes one specific for fiberglass. I cannot recall the name.
747 10-01-2013 12:24 AM
If you mean sw All Surface Enamel Latex Primer I have never used it. So check with guy at SW and make sure exterior superpaint over it is ok.
jerome8283 11-02-2013 09:15 PM
I received my fiberglass entry door today. Love the door but one problem; only one hole was drilled for the hardware. Of course I requested two holes. I spoke to the installer about it and asked if making an additional hole would be a problem. He said the integrity of the door might be compromised.
Is this true?
spraygunn 11-02-2013 10:01 PM
It’s Friday, and he wanted to go home early. If he had to bore a second hole he wouldn’t be leaving as early as he wanted to. If that second hole will compromise the integrity then there’s a lot of compromised doors out there. To answer your question........NO.
jerome8283 11-03-2013 07:30 AM
Sorry I should have been more clear. I purchased the door separately. Where I purchased the door is where the second bore should have been made.
I asked the installer who is not associated with the place I purchased the door from to make the hole and he made the integrity comment. I haven't spoken to him in detail yet.
ToolSeeker 11-03-2013 08:12 AM
First I would deal with the place of purchase if it was ordered with 2. Unless he is seeing something we are not because he is on site and we are not, it sounds like he doesn't have much experience with doors and is a little leary of drilling. A lot of guys feel this way because a little screw-up and they bought a door. But again he may be seeing something we can't.
jerome8283 11-03-2013 08:15 AM
I intent to call the place tomorrow. The installer hasn't seen the door yet. I informed him of the missing hole via text only.
jerome8283 11-04-2013 09:27 AM
All is good now. The installer having not seen the door made the integrity comment because he did not know whether the door was blocked in the area where the second deadbolt hole would be drilled. I confirmed it was blocked and even obtained the technical diagram online. The installer will drill the second hole. Thanks!
RunningSparky 11-04-2013 10:35 AM
If not too late, might confirm with manufacturer that by boring another hole will not void your warranty. Just a thought...
jerome8283 11-04-2013 10:44 AM
Good suggestion. I spoke to the manufacture directly and it will not void the warranty. Thanks
jerome8283 11-17-2013 12:17 AM
I'm ready to paint. I have SW All Surface Enamel Latex and their Multi Purpose Primer. It is recommended to clean the door with mineral spirits and wash it down with a warm soapy detergent. How long should it dry after the cleaning? Is it possible to accomplish all of the above in one day?
I meant to ask about applying time between coats. I was confusing the recoat times with actual drying times. I understand the complete drying times can take a few days. I see the Enamel Latex states 4hrs for recoating times but I guess I will require more time since the temperature is 55-65 degrees. I'm painting with the door open and I'm putting up plastic in the doorway so it will be a bit warmer due to the inside temps.
Roller vs. brush? I see some due both. First coat is brushed and the second is rolled. Any opinions here? What kind of roller?
Jmayspaint 11-17-2013 09:16 AM
I'm curious about the cleaning recommendations. Recommended by whom?
Mineral spirits seems like an odd choice of solvent to me because it leaves an oily film on the surface that can interfere with adhesion of latex products. Presumably the second wash with warm soapy water would remove the film, but it just seems odd to me. The data page simply says to clean with an 'appropriate' cleaner.
I would skip the mineral spirits and just clean with soapy water. Or if a solvent was needed, use one that evaporates cleanly like denatured alcohol or lacquer thinner.
Maybe I'm missing something here, any other pros know why you would clean fiberglass with mineral spirits specifically?
However you clean it, it shouldn't take too long to dry. Fiberglass won't absorb moisture like wood will, so a couple hrs dry time should be enough.
The multi purpose primer dries for recoat in one hour under normal conditions. If its a little cool, give it two hours.
jerome8283 11-17-2013 09:21 AM
I have seen mineral spirits mentioned multiple times via a search. Also I found this, http://www.masonite.com/pdf/finishin...tentrytear.pdf. My door is Masonite brand.
