Painting Skirting Boards - Painting - DIY Chatroom Home Improvement Forum
Old 08-06-2011, 01:33 AM   #1
Painting skirting boards
Can I use an acrylic flat primer and then a semi-gloss oil-based enamel on top?
elizann is offline   Reply With Quote
Old 08-06-2011, 06:51 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
You can, but the flat primer will not help you to develop the sheen of the top coat. A primer called " enamel underbody" is made to do this.
I assume you are talking about over raw wood, not previously finished?
Would mean different answer-
Brushjockey is offline   Reply With Quote
Procedure on re painting barge/facia boards. schermd Painting 13 03-31-2011 07:35 AM
stair skirting boards nanna Carpentry 3 11-27-2010 10:05 PM
Painting Skirting Boards and paint dripped into the tile grout naomit111 Painting 2 11-10-2010 10:04 AM
painting trim and base boards fabian Painting 19 10-10-2010 02:48 AM
priming & painting T&G porch boards GlennW Painting 7 09-07-2009 10:19 PM
