#1 |
painting skimmed walls
My wife and I had the knock down texture removed by a company. the walls are left all white. Now typically there would be drywall and tape and mud, but these walls are all mud. any special instructions to priming and painting?
#2 |
paper hanger and painter
I would prime with Gardz, in this case maybe 2 coats, then 2 finish coats.
#3 |
Rubbin walls since'79
While I won't argue with Gardz- I will ask what is the sheen of the paint you plan on finishing with?
Gardz will be great for a seal for an eggshell finish , you can even add about 25% of your finish coat to it to give a little color ( depending on paint compatibility) . But if you are going flat that might be overkill. A good drywall primer that is flat would be sufficient. Why, I just skimmed and primed a bath myself today. Used Zinsser Zero 123 as my prime. Worked as expected, will paint eggshell tomorrow. |
#4 |
How about if i use PVA with a tint for the flat walls. most will be flat. only the kitchen will be semi. I was told a tint might not have me having to do two coats. I prefer Sheman williams. Your preferences would be welcomed. thanks. It's a big job as the WHOLE home was resurfaced.
#5 |
With a skim, prime and 2 finish is the norm. i almost never use a PVA- go for more the sealer-primers, But then i also almost never finish walls in flat.
Just don't use crap materials. You sound like you had a nice job, don't cheap it out now. |
#6 |
Sheman? Williams, Don't say that to them.
Sometimes I just don't have anything productive to say.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 |
Oops. sorry sherman.. So the best sealer is what? and the best paint in your opinions is?? I value it and I won't cheap out..
#8 |
Try Sherwin Williams. Covers the world, don't cha know...
#9 |
Learning by Doing
Look up your closest paint supplier. Patronize a locally owned business (if they treat you right) and buy a TOP quality product.
If I could only remember to THINK about what I was doing before I did it. |
#10 |
If going to SW then these 2 would work
| Display Modes | |
| Painting Calcoat Plaster Walls | Rlearn | Painting | 0 | 03-14-2011 11:51 PM |
| Painting soot covered walls | syogod | Painting | 11 | 12-22-2010 12:37 PM |
| painting old cob walls | gricean | Painting | 5 | 11-26-2009 08:22 AM |
| painting a room w/ both drywall and plaster walls | J187 | Painting | 7 | 06-19-2006 06:33 PM |
| painting 18' walls | sedona48 | Painting | 1 | 02-07-2004 07:18 PM |
