-   -   painting skimmed walls (http://www.diychatroom.com/f4/painting-skimmed-walls-112033/)
n224ap 07-26-2011 02:23 PM
My wife and I had the knock down texture removed by a company. the walls are left all white. Now typically there would be drywall and tape and mud, but these walls are all mud. any special instructions to priming and painting?
chrisn 07-26-2011 04:50 PM
1 Attachment(s)
I would prime with Gardz, in this case maybe 2 coats, then 2 finish coats.
Brushjockey 07-26-2011 05:10 PM
While I won't argue with Gardz- I will ask what is the sheen of the paint you plan on finishing with?
Gardz will be great for a seal for an eggshell finish , you can even add about 25% of your finish coat to it to give a little color ( depending on paint compatibility) .
But if you are going flat that might be overkill. A good drywall primer that is flat would be sufficient.
Why, I just skimmed and primed a bath myself today. Used Zinsser Zero 123 as my prime. Worked as expected, will paint eggshell tomorrow.
n224ap 07-26-2011 06:32 PM
How about if i use PVA with a tint for the flat walls. most will be flat. only the kitchen will be semi. I was told a tint might not have me having to do two coats. I prefer Sheman williams. Your preferences would be welcomed. thanks. It's a big job as the WHOLE home was resurfaced.
Brushjockey 07-26-2011 06:43 PM
With a skim, prime and 2 finish is the norm. i almost never use a PVA- go for more the sealer-primers, But then i also almost never finish walls in flat.
Just don't use crap materials. You sound like you had a nice job, don't cheap it out now.
jsheridan 07-26-2011 06:44 PM
Sheman? Williams, Don't say that to them.
Sometimes I just don't have anything productive to say.
n224ap 07-26-2011 07:10 PM
Oops. sorry sherman.. So the best sealer is what? and the best paint in your opinions is?? I value it and I won't cheap out..
Brushjockey 07-26-2011 09:06 PM
Try Sherwin Williams. Covers the world, don't cha know...
Leah Frances 07-26-2011 11:26 PM
Look up your closest paint supplier. Patronize a locally owned business (if they treat you right) and buy a TOP quality product.
chrisn 07-27-2011 05:24 AM
2 Attachment(s)
If going to SW then these 2 would work
n224ap 07-27-2011 03:45 PM
Thanks guys
