Painting On Silicone - Painting - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-18-2014, 09:56 AM   #31
Okay.. Thanks Gymschu
appreciate your reply... going to Home Depot later today
have good day
Mamacat104 is offline   Reply With Quote
The Following User Says Thank You to Mamacat104 For This Useful Post:
Gymschu (05-18-2014)
Old 05-18-2014, 01:59 PM   #32
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,622
Just thinking outside the box... which is not always good....
You could paint all the fence white......
MTN REMODEL LLC is offline   Reply With Quote
Old 05-18-2014, 02:06 PM   #33
This is true.. I also thought about painting black and using n outline design in white and then paint the design in the center white. that would be unique
Old 05-19-2014, 03:54 PM   #34
RoundedRooster's Avatar
Can you trim as much white caulk off as possible? Maybe with a utility and scraper? If you can, then try using the BLACK 3M 5200 to form a nice bead over the top of the trimmed white. That way you adhere to the same compound. Then paint using techniques and paint types suggested here. That way you paint over black urethane and if it peels or cracks it won't be so noticeable. Acetone might help bond the black 5200 to the white 5200 and help with creating a smooth bead, unless someone here knows a better way.
RoundedRooster is offline   Reply With Quote
Old 05-19-2014, 04:08 PM   #35
Thanks RoundRooster... just finished painting ... I painted on Bin Primer...yesterday and today did the black rust-oleum... go figure.. the black paint didn't want to cover the primer.. had to put on one coat that was streaky.. then went back with 2nd coat in few minutes to cover the streaks... don't know if it will stay on or not... will see...
appreciate suggestion... will see what happens now after this dries and go from there...
have a good day
RoundedRooster (05-19-2014)
Apply alex plus latex caulk plus silicone TWICE sannitig Painting 2 02-26-2013 12:01 PM
painting my mom house supaflyz Painting 5 07-28-2009 03:34 PM
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 06:52 AM
Help! Painting problems on my finished garage mad dog Painting 7 07-23-2009 05:19 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 03:33 PM
