Old 06-02-2008, 01:18 PM   #1
painting side by side front steel doors
Hello Ideas please!
I have two steel double doors to re paint.
Each has some blistered / bubbles in some areas, I plan on sanding and filling these areas with filler. like a bondo, to get the same smooth finish,
whole process seems to be a slow process if done right.
The question I have is: these doors get real hot from the morning sun, for about 3 to 4 hours, today they were so hot i could not put my hand on either one.
I'm open for suggestions on the best paint to use.I thought a spray pain would give a real nice finish? But i would like a brush mark free paint job.
But I will pay for the good paint I want a nice looking job.
I have years of painting but I have never had to paint metal doors to take the hot sun.
old salt
old salt is offline   Reply With Quote
Old 06-02-2008, 02:20 PM   #2
Originally Posted by old salt View Post
Hello Ideas please!
I have two steel front double doors to re paint. ( Home)
I'm open for suggestions on the best paint to use.I thought a spray pain would give a real nice finish? A brush mark free paint job is my aim.
But I will pay for the good paint and good primer, I want a nice looking job to last for years!
old salt
I forgot to mention it looks like the metal under the chiped paint ( is galvanized ) or coated metal
Old 06-03-2008, 09:53 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Hmmm...I wonder if it bubbled from the heat, or if the wrong coating (paint) was used?
Is it just one layer/color peeling up?
How old are the doors?
slickshift is offline   Reply With Quote
Old 06-04-2008, 09:18 AM   #4
The doors are about 18 years years old, I peeled a chip of paint off and
it looked like only the original first coating of paint.
A white primer with a posible two coats of green top coat, type of pain what ever the manufacture used ( ? ) no name as to the manufacture,
I can see the metal has a coating on the under surface.
I can sand and fill any un-eveness area, I would rather not strip the whole two doors, But I do have a heat gun, if need too. I rather not use chemicals on metal doors. especialy if there is an under coating to be ruined.
I will start this project in two weeks !
old salt
deck hand is offline   Reply With Quote
Painting over polyurethane coated wood doors flashme18 Painting 9 04-19-2008 10:51 PM
Painting interior doors Pawl Painting 28 03-15-2008 05:43 PM
Painting the inside side of Tar Paper; unfinished detached garage cityparkmark Building & Construction 8 03-03-2008 10:15 AM
Painting Old Hollow Doors diywoman Painting 12 02-02-2007 07:52 AM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 11:16 PM
