painting side by side front steel doors
Hello Ideas please!
I have two steel double doors to re paint. Each has some blistered / bubbles in some areas, I plan on sanding and filling these areas with filler. like a bondo, to get the same smooth finish, whole process seems to be a slow process if done right. The question I have is: these doors get real hot from the morning sun, for about 3 to 4 hours, today they were so hot i could not put my hand on either one. I'm open for suggestions on the best paint to use.I thought a spray pain would give a real nice finish? But i would like a brush mark free paint job. But I will pay for the good paint I want a nice looking job. I have years of painting but I have never had to paint metal doors to take the hot sun. :huh: old salt |
Hmmm...I wonder if it bubbled from the heat, or if the wrong coating (paint) was used?
Is it just one layer/color peeling up? How old are the doors? |
side by side doors bubbling paint
it looked like only the original first coating of paint. A white primer with a posible two coats of green top coat, type of pain what ever the manufacture used ( ? ) no name as to the manufacture, I can see the metal has a coating on the under surface. I can sand and fill any un-eveness area, I would rather not strip the whole two doors, But I do have a heat gun, if need too. I rather not use chemicals on metal doors. especialy if there is an under coating to be ruined. I will start this project in two weeks ! :) Thanks old salt |
| All times are GMT -4. The time now is 04:03 PM. |
