Painting With Shellac - Painting - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 11:43 AM   #1
Painting with shellac
Can you use Zinsser's bull eye shellac on rusting non-galvanized screws on latex painted outside hinges to stop them from "bleeding" a rusty color?
Jeanne Conly is offline   Reply With Quote
Old 07-22-2012, 11:51 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
Yes, but I think an oil primer might be better- not as brittle outside, and Shellac does transfer moisture - just a little- .
Try Cover Stain.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-22-2012, 01:42 PM   #3
(the original)
Rewards Points: 756
Unless you remove all the old paint and rust, shellac won't last long. As Brush said, you'll do better with an oil. Better yet would be a rust conversion product. Or...best of all, remove the screws and replace with brass, galv, or coated exterior screws.
ratherbefishin' is offline   Reply With Quote
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 10:42 AM
Shellac for floor finish Joe1. Flooring 2 11-23-2010 12:28 AM
painting exterior door JP79ST Painting 18 05-18-2010 04:04 AM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
