-   -   Painting Sheetrock (http://www.diychatroom.com/f4/painting-sheetrock-6258/)
helpless handyman 02-01-2007 07:00 PM
Painting Sheetrock
I am getting ready to start priming my new sheetrock walls. Whats the best size of nap roller cover for this? 1/2, 3/8, 1/4? Thanksl
slickshift 02-01-2007 08:10 PM
1/2" premium quality roller sleeve
Brik 02-02-2007 10:34 AM
Why do you suggest 1/2" I'm curious. I am using 3/8" on mine right now and it seems to be going OK. A bit slow though. Will 1/2" speed up the process because it can hold more paint? Or, will 1/2" put more paint on the wall, hence I will use more paint? Do you recommend 1/2" because it will leave a bit more texture?
slickshift 02-02-2007 12:31 PM
1/2" will speed up the process considerably
It holds much more paint, which means less dipping, which costs a fair amount of time...time that is not spent applying paint
It also means less over-lapping with "fresh" and "applied" paint, less chance of lap marks, less need to maintain a "wet edge"...
The 1/2" really doesn't leave more stipple (texture)
Not with a quality paint that has some leveling properties
That and the quality of the sleeve are more determining factors
I really recommend 1/2" as a minumum
Even for DIYers and n00bs
The only thing that might out-weigh the nap size is sleeve quality
If I've got a choice between an iffy 1/2" nap, or a quality 3/8", I'll (hesitantly) take the quality 3/8" over the iffy 1/2"
It'd have to be a choice of one or the other though
I'd never willingly pick up a 3/8" if I could use a 1/2" +
Brik 02-02-2007 12:56 PM
Hmm. How about for the finish coat, not the primer? Same advice?
I am currently priming my Sheetrock on a basement finishing project. I have gone through 5 gallons of primer so far. I started with a 3/8" roller of unknown quality. It did not leave fuzz and I had zero issues with lap marks or other problems. Only 'problem' was the drywall sucking up the paint. This caused things to go slow and use a fair amount of paint (it seemed to me).
I decided to try one of those paint stick things. It also had a 3/8 nap. It DID speed up the priming process but added time to the cleanup. For longer stints of priming it definitely saved time. I would not even consider it if I was only going to paint/prime for an hour.
slickshift 02-02-2007 01:21 PM
Yup
The same
joewho 02-02-2007 05:14 PM
Primer dries to less thickness than paint, and once you have a little bit of experience you might try a 3/4" 50/50 sleeve. On new construction you can use the 3/4 for everything, or if not, then use 3/4 for everything except your top coat. This will speed things up because a good sleeve picks up and releases more paint. Meaning more sq.ft. of coverage per dip. It doesn't use more paint on the overall job.
helpless handyman 02-02-2007 08:06 PM
Thanks guys, I am using purdy rollers:thumbup:
jmthouston 02-17-2007 12:05 AM
look at this
:thumbup: http://www.bigkahunaroller.com/ much faster no and Brik what do you mean by sticky thing -Emulsabond could you please clarify thanks
slickshift 02-17-2007 07:54 AM
Minimum quality Purdy I'd recommend would be White Doves
Brik 02-17-2007 08:25 PM
Ah the stick thing...
http://www.wagnerspraytech.com/porta...al-rollers.jpg
^^^^^^^^^Thats not me!^^^^^^^^^^^^^
She is using a paint stick. The paint goes into the handle and pushes out the roller. Holds about 1/2 quart at a time I think. Cost about $20. http://www.wagnerspraytech.com/porta...41919,747.html
slickshift 02-17-2007 08:35 PM
No it's not you at all...usually you wear your hair down, Brik
Nice look for you though
Makes you look more sofisterkated
boman47k 02-18-2007 08:33 PM
Heheh, got one of those once. Never again.
