-   -   painting sheet metal ceiling (http://www.diychatroom.com/f4/painting-sheet-metal-ceiling-93040/)
amakarevic 01-21-2011 03:14 PM
i have a rustical old sheet metal ceiling that came with the 100 yr old house. has some relief pattern on it. was wondering if it should prime it before painting or just paint like the walls.
thanks
Windows 01-21-2011 06:44 PM
That, you may need to paint with oil.
Thurman 01-22-2011 10:16 AM
IF you are talking about the really old square panels: I love 'em. I saw this trick done some years ago when those older panels were used in a new home: IF your panels have any "relief" or slightly raised areas, then paint the color of your choice and allow to dry. Then go back with a sponge and lightly touch the raised areas with a contrasting paint or a paint which would blend with your color. This was done every so lightly on the one's I saw. They had used a dark blue base color with a "gold-tone" on the relief. It was awesome.
poppameth 01-22-2011 11:16 AM
It needs a good cleaning before anything else. Once cleaned I'd probably go with a good Acrylic DTM Primer and Paint. I don't have much experience with these tiles, but I know modern ones are usually made from tin. I believe older ones were as well. Tin doesn't really get along well with oil products. Acrylics bond to them much better.
mazzonetv 01-22-2011 11:33 AM
are they already painted or down to the bare metal? Are they rusted at all? do you have any pics??
Windows 01-22-2011 03:13 PM
I think that is true with galvanized metal. Metal ceiling panels are tin plated steel and water based paint can/will rust them depending on how they were finished previously. Without more info from the OP, they should be treated with oil.
poppameth 01-23-2011 11:52 AM
Galvanzied, tin, and aluminum don't really like oil. If the tin has started to rust, then oil will work fine on it.
epson 01-23-2011 12:19 PM
I did this awhile back and this is what you should do. First wipe down the ceiling panels with a damp rag to remove any surface dirt and if there are any small rust spots, carefully sand them away. Next use a lambís wool roller to apply a good quality latex paint; lambís wool will spread paint into all crevices of the ceiling pattern and apply at least (2) good even coats be sure to allow even drying time in between the first and second coats. Also if you want to bring out the pattern, apply paint to them in a complementary color with a smaller detailing brush and once all paint is dry, brush on a protective coat of varnish to prevent paint chipping and you will have a stiff neck and a beautiful ceiling.
amakarevic 01-23-2011 04:44 PM
1 Attachment(s)
thanks everyone. here is a decent photo of the transition between the wall (bottom of pic) and the ceiling (top) with some molding in between that i think is the same material as the ceiling. the house is 100 y/o and so i suspect is the sheet metal ceiling.
mazzonetv 01-23-2011 04:55 PM
from looking at the picture I don't see any reason to prime. The paint on there now seems to be in good condition, I don't see any staining, flaking, peeling, bare spots, etc.. From the pic, it appears to be a flat, i'm assuming latex, paint on there now. so to answer your question - if the rest of the ceiling looks like that I don't see any reason why you can't just go right over with another latex paint.
amakarevic 01-23-2011 05:04 PM
so you're saying just use the same exact paint as the wall, correct?
mazzonetv 01-24-2011 12:11 PM
Yup - from looking at those pics don't see any reason to use anything else.. Typically you would use a flat for the ceiling though so If you are doing eggshell or any higher sheen on the walls, I would get a flat for the ceiling.
amakarevic 01-29-2011 02:38 PM
But I was actually thinking to get satin for the ceiling because i thought shininess would look good with this kind of texture/relief/material. what do you think ?
chrisn 01-29-2011 05:14 PM
It's only paint. If you do not like the shine of the satin ( I would not), paint it flat. Sort of like the song:laughing:
