Painting Shed - Painting - DIY Chatroom Home Improvement Forum
Old 02-16-2010, 12:57 PM   #1
Painting shed
I just read your post regarding oil vs latex for interior exterior, etc. and have a question. I am going to be painting 3/4 inch untreated yellow pine plywood floor inside my new 8 x 12 shed. I know I want to use an oil based primer; however, should I just use an oil based paint or the oil based floor and porch paint for the topcoat. I read what you said about the expansion and contraction of wood outside vs. inside, but would this hold true for an interior shed floor that is out of the elements? I just want a good surface that will hold up to push mower, wheel barrel, foot traffic, and something that might clean up well in case I get some grease on it or something like that.
Thanks in Advance!!!
Tkane01 is offline   Reply With Quote
Old 02-18-2010, 11:12 AM   #2
Rewards Points: 252
one thing to keep in mind - Maryland falls under the OTC regs concerning VOC limits in paint. It might be very difficult to find a good quality Oil based exterior paint. Depending on what you find, you might want to look into Solid deck stains for your floor. For the railing and trim I agree that nothing looks nicer than an oil based finish - but the stuff isn't what it used to be. Do you know what type of wood? I would probably play it safe and prime with a high quality oil based primer - there are some good penetrating alkyd primers out there -but keep in mind they take a very long time to dry so you want to make sure the weather is appropriate. After priming I would personally use a 100% acrylic latex - just think they are getting better all the time and the oils are getting worse as all the "good" stuff is being taken out due to VOC regs.
Might be a good idea to go to your local paint stores, see what products are available locally and see what they suggest.
Good luck whatever you decide.
mazzonetv is offline   Reply With Quote
Old 02-18-2010, 11:32 AM   #3
New question moved to a new thread
One problem with adding a new question to a thread is that people read the original question & respond to that
Old 02-18-2010, 11:41 AM   #4
Rewards Points: 252
my reply was actually intended for the OP on the other thread - which I can't find anymore.
water run off in shed kathy k Building & Construction 4 08-09-2009 03:29 PM
Arrow shed on angle concrete foundation - how to fix? norcalty Building & Construction 4 06-18-2009 06:28 AM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 11:09 AM
Painting an Aluminum Shed hgiljr Painting 2 02-25-2009 07:46 PM
Shed Wiring bcdal Electrical 12 03-26-2008 04:51 PM
