Painting Semi-gloss Over Semi-gloss Trim - Painting - DIY Chatroom Home Improvement Forum
Old 09-29-2010, 12:15 PM   #1
painting semi-gloss over semi-gloss trim
I picked a semi-gloss white that was too white for my trim. We put on 2 coats. Then I went and bought what I thought would be a more subtle white and put 2 more coats on. It is still TOO white and now I want to go to an antique white. But now I have 4 coats (not counting the original paint) of semi-gloss on the trim. Will I need to sand some of it off so that the new paint will stick. Or can I just put a coat of primer on first?
judyborland is offline   Reply With Quote
Old 09-29-2010, 05:02 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 504
Either will work, youd don't need to sand it hard, just lightly.
chrisn is online now   Reply With Quote
Old 09-30-2010, 09:23 AM   #3
painting over semi gloss trim
Its always best to sand and clean before applying a new coat to glossy paint. However if the coats that you have been putting on are fresh (with in 30 days) and they are sticking, then you likely could just re-paint without sanding, but I would reccomend testing it first by doing a section and checking with your fingernail 24 hours later.
www.PearlPainters.com
Painters in Lake Oswego Oregon
Pearl Painters is offline   Reply With Quote
The Following User Says Thank You to Pearl Painters For This Useful Post:
hammerheart14 (10-01-2010)
Old 10-01-2010, 12:17 PM   #4
Rewards Points: 150
once again, you know your ****!!!
hammerheart14 is offline   Reply With Quote
painting trim with semi gloss paint sninny Painting 10 09-21-2012 04:33 AM
Painting fireplace & trim? bltwa Interior Decorating 4 03-08-2009 01:57 AM
painting over semi gloss on walls? MHG Painting 3 01-10-2009 02:46 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
Cabinet Painting: Gloss vs. Semi Gloss digexpressions Painting 1 12-29-2007 03:47 PM
