Painting A Screened Porch - Painting - DIY Chatroom Home Improvement Forum
Old 03-18-2013, 09:32 AM   #1
Painting a screened porch
I need to paint the interior of a screened porch. Actually it has combination windows, so it is dry, but unheated. I have several questions.
One wall is stucco, which is the exterior of the house, the other three walls painted wood. Can I use the same paint for all surfaces? Is there any advantage to using exterior or interior paint for this project?
I want to use a flat finish, the wood portions aren't exactly perfect. I am painting to sell, so I am not concerned with buying the most expensive paint to last a lifetime. Appearance is my main concern.
It is currently painted a putrid shade of green. I will be painting white. Is it best to prime first or will I get the same results with multiple coats of paint?
I know the temperature is supposed to be above 50 degrees with most paint. Is there a little more "wiggle" room when you are painting an enclosed area? Is it really the temperature or the moisture that matters? Do I just need a couple hours above 50 for drying or does it have to be above 50 overnight?
Lots of questions. Appreciate any help you can give. Thanks
paullo is offline   Reply With Quote
Old 03-18-2013, 07:31 PM   #2
The same paint can be used for all surfaces. Priming is unnecessary if it's previously painted. Yes, use exterior paints. Some exterior paints now go down to 35 degrees. Read the instructions on the can as to temp and painting. It varies, but whatever it tells you I would adhere to closely.
Old 03-18-2013, 09:16 PM   #3
Roofmaster
Rewards Points: 2,172
Put up some heavy plastic outside with wood battens and run a kerosene convection heater in there and go to town. I would not even think about painting below 55 degrees. The paint will not flow right or level out properly.
Replacing Deck Boards on Screened in Porch kendoit Building & Construction 12 01-24-2017 02:34 PM
Screened porch project harri320 Project Showcase 26 09-13-2016 09:19 AM
Screened In Porch Rebuild or Repair? Cowead Building & Construction 9 10-27-2012 10:51 PM
Screened porch & deck MARICHTER Building & Construction 3 09-10-2012 09:57 PM
Need Help - Installing Hot Tub on Elevated Screened Porch Floor!!! rpr Building & Construction 12 09-20-2011 03:54 PM
