Painting A Scooter - Painting - DIY Chatroom Home Improvement Forum
Old 10-06-2008, 04:01 PM   #1
painting a scooter
hey guys im new here and i have a question about painting plastic (it might be fiberglass(?))
anyway i bought a scooter earlier this summer and decided that i want to go ahead and paint it. i stripped the plastics off and sanded the glossy finish down and im left with this
i then go out to home depot and buy some automotive primer in a spray can thinking that automotive primer would stick to it
i did a test patch on one of the pieces and im now stuck with this
the one coat of primer scratches right off under my fingernail as shown ^^^
what type of paint should i be using on this?
dorado29 is offline   Reply With Quote
Old 10-06-2008, 04:47 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
I think with Fiberglass you want to use an epoxy based primer but something is up if your automotive primer is just scraping off that easy. Exactly what brand primer is it ?
Old 10-06-2008, 04:50 PM   #3
rustoleum auto primer
can i please have some more info on the epoxy based primer? would i be able to spray paint on top of it?
Old 10-06-2008, 07:58 PM   #4
What did you use to wipe it down after you sanded? Also, what grit sand paper did you finish with?
jerryh3 is offline   Reply With Quote
Old 10-06-2008, 08:30 PM   #5
the Musigician
DangerMouse's Avatar
perhaps it has wax on it?
DM
Old 10-06-2008, 09:06 PM   #6
i used a wall sander kind of thing for the bulk of it along with sand paper which i have no idea what grit it was to finish+get to the hard to reach stuff
Old 10-06-2008, 09:15 PM   #7
Sand the primer off. Go over the entire thing with a scotch-brite pad (maroon/general purpose). Blow off the dust with compressed air or wash it down with soap and water. Dry it. Put latex gloves on and wipe the entire thing down with a grease/wax remover and then wipe it down with a tack cloth. Then you'll be ready to paint.
Old 10-06-2008, 09:16 PM   #8
the Musigician
can you afford to take it to an autobody place that sandblasts? if it EVER was waxed, you'll have these exact problems with ANY paint you try to put on it.
DM
Old 10-06-2008, 11:07 PM   #9
Rewards Points: 2,906
If the material you're trying to paint IS fiberglass, I'd be inclined to phone up any auto body shop and ask if they use a different primer when repairing and repainting Corvettes. My understanding is that the body of Corvettes are made of fiberglass, not steel.
Also, any marina would know who to refer you to who repairs fiberglass boats (and canoes). Someone familiar with repairing fiberglass would know if you need to use a special primer on it.
If that primer comes off just by scratching it, you might be able to remove the primer fast 'n easy by sticking duct tape to it, and then pulling the duct tape off. Or, any really tacky tape, like packaging tape, which is far cheaper than duct tape.
Nestor_Kelebay is offline   Reply With Quote
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 04:07 PM
