Old 03-15-2009, 10:58 PM   #1
Painting safely on a roof??
I need to paint on my roof which is on a slant. Is there some sort of structure I could build with wood (2by4's) to attach to my roof? I CAN nail into my roof but just not into the shingles. I was thinking of building a structure about 8 feet wide that would make myself level with the ground. I'm just having problems with attaching it to my roof. Any idea? Any links to images of completed structures or scaffolding? Is there a simple solution to my problem? Thanks!!
GrowUpNow is offline   Reply With Quote
Old 03-16-2009, 12:41 AM   #2
Tom Struble's Avatar
check out rent all place they have the proper scaffold you can rent and i would encourage you to wear a safety harness with the safety line properly anchored and be very careful i hear of people falling and the results are usually not good, some jobs for some peopls are better left to a pro
Tom Struble is offline   Reply With Quote
Old 03-16-2009, 12:48 AM   #3
How do I put a safety anchor on/in my house? Do I screw it in my siding? I'm around 250 lbs. What kind of safety equip would work for me?
Old 03-16-2009, 01:00 AM   #4
go to a roofers supply company in your area they can outfit you properly for a couple of hundred dollars
read and follow all the instructions that come with your safety equiptment
Tags
painting, roof, safety, structure
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 08:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
