Painting Rusting Garage Door - Painting - DIY Chatroom Home Improvement Forum
Old 08-06-2008, 12:02 AM   #1
Rewards Points: 462
Painting rusting garage door
My garage door is starting to show some surface rust and I was wondering if there was an effective way to paint over it and stop the rust in its tracks. I tried doing this with an old van years ago and even though I sanded, primed and painted over the rust (rust inhibiting primer & paint) the rust still came through the paint after less than a year.
Looking for any advice on dealing with this before it really gets out of hand.
Thanks!
Richo is offline   Reply With Quote
Old 08-06-2008, 06:51 AM   #2
Guest
Guest
Posts: n/a
Red Oxide primer would suffice for quite a while with no more rust than you have there. It'll help keep it under control for many years. Once it gets worse, or even now if you want to go ahead with it, you can apply a product such as Ospho, which is an acid etcher that neutralizes the rust and converts it into a type of primer which you can paint right over.
Old 08-10-2008, 02:51 AM   #3
EPI
Painter
EPI's Avatar
I'd sand, prime with Red Oxide primer and apply An industrial enamel.
EPI is offline   Reply With Quote
Painting a garage door dfoxworthy Painting 6 06-22-2008 11:51 PM
Painting a wood garage door? sandyman720 Painting 8 03-31-2008 11:54 AM
Painting inside of garage door PUNISHER VETTE Painting 10 07-11-2007 12:06 AM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
