Old 11-28-2008, 12:01 PM   #1
Painting rough Plaster
I'm about to remove wallpaper that has been on our parlor wall for over
100 years. Of course there is about 8 layers or more.
From past experance I had to re wall paper because of the very rough plastered surface of the wall ?
This time I wish to paint the walls after stripping the wall paper off (( wish me luck ))
Has anyone out there had and solved this problem?
I assume there is a certain kind of method to paint the rough surface and or an additive for the paint to set up a smoother surface.
Starting next week.
deck hand
deck hand is offline   Reply With Quote
Old 11-28-2008, 09:57 PM   #2
You're scared you won't be able to contend with a rough surface on a wall. You just need to know some tricks.
There are two ways to skim coat over a wall:
Method #1:
A. Buy a "V" notched adhesive trowel, and apply drywall joint compound (thinned with some water to make it easier to spread) with the "V" notched side of the trowel and allow to dry.
B. When dry, knock off any blobs of joint compound that are sticking out of the trowel ridges, and apply more thinned joint compound holding the trowel upside down so that you fill in the trowel ridges with more joint compound using the un-notched edge of the trowel.
Method #2:
C. Do the same as in "A" of Method #1, but then...
D. Mist the drywall joint compound with a spray bottle so the surface is wettER, and smooth down the joint compound trowel ridges so they're flat using the un-notched edge of the trowel.
In both cases you'll spread a pretty uniform coat of joint compound over the wall which you can then sand smooth, prime and paint.
And, ALWAYS, ALWAYS, ALWAYS when doing plastering or drywall work, have a bright light close to the wall you're working on to exagerate the roughness of the wall. This will give you a much better mental image of where you need to add joint compound and where you need to remove it in order to get the wall smoother. When the wall looks OK under such critical lighting, it'll look perfect under normal lighting.
Nestor_Kelebay is offline   Reply With Quote
Old 11-28-2008, 10:06 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
If you have rough plaster and want it smooth, you'll need to replace it with sheetrock, or "skim coat" the whole nine yards with a thin layer of joint compound
*There is something to be said for keeping that old school rough plaster look in an older home
It's trickier to paint...well, to make it look good...it's harder to choose lines and such...and choosing what to sand, how far, etc...
You want to make it look like "it's supposed to look that way"
One of the best most rewarding jobs I've been on we kept that old stuff
Even the plaster repairs (for electrical) were plastered a little sloppy on purpose to keep the look
Some areas we had to sand a little smoother, some not, some we didn't decide until after a coat of primer, some not until after the first coat of paint
(some trim we even left broken!...with a little smoothing from fillers an caulk)
The end look was totally killer and would be difficult (if not impossible) to replicate at any price
slickshift is offline   Reply With Quote
Old 11-29-2008, 06:45 PM   #4
Method #1:
Method #2:
This sound like a lot of work ( But ) rewarding . I'll have to see the condition of the plaster.
I can do This. I can do this I can I can.
Deck hand
Old 11-29-2008, 06:47 PM   #5
^Thanks I must see what's under that wall paper.
Then go from there.
Deck hand
Painting Rough Pine is it possible rdalrymple Painting 7 11-24-2008 08:57 PM
Painting Plaster or repair/replace? jdirish Painting 3 03-12-2008 11:03 AM
Painting New Plaster Bill45 Painting 2 04-06-2007 01:03 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
