Painting A Room With Crown Molding - Painting - DIY Chatroom Home Improvement Forum
Old 10-20-2011, 11:17 AM   #1
painting a room with crown molding
I need to paint a room with crown molding. For ceiling I am using Benjamin Moore Waterborne Ceiling Paint (off white), crown is semi-gloss white, walls are brown. When I cut the ceiling, do i need to worry about getting ceiling paint on the crown? I am guessing when I cut the crown, semi-gloss will cover ceiling paint that gets on the crown
net_tech is offline   Reply With Quote
Old 10-20-2011, 01:00 PM   #2
ltd
Rewards Points: 536
yep that's right but just feather it on dont have a build up paint that's leaves ridges.you can also do the same for the crown to the wall.
ltd is offline   Reply With Quote
The Following 2 Users Say Thank You to ltd For This Useful Post:
m1951mm (10-20-2011), net_tech (10-20-2011)
Old 10-20-2011, 01:34 PM   #3
m1951mm's Avatar
You are right LTD, as long as the poster knows what feathering is. Feathering is making sure there are no hard lines left of paint that will dry to leave ridges for the second coat coming. Taking the tip of the brush and smooth out the overage on the crown or other surface that will be painted next. P.S. tape is for securing boxes, not for painting .
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
The Following 2 Users Say Thank You to m1951mm For This Useful Post:
ltd (10-20-2011), net_tech (10-20-2011)
Old 10-20-2011, 02:27 PM   #4
Thank you for your comments
What brush would you recommend for cut in work round or 2.5 angled XL Purdy?
Old 10-20-2011, 05:24 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
I use a 2 1/2 for almost everything( although not necessairly a Purdy)
Old 10-20-2011, 05:33 PM   #6
Gymschu's Avatar
Rewards Points: 184
I know a lot of painters swear by their Purdy brushes, but, I love Wooster brushes best.
Gymschu is online now   Reply With Quote
Old 10-20-2011, 06:16 PM   #7
Rubbin walls since'79
Brushjockey's Avatar
Wooster Alpha FTW!
(Painters argue over this stuff all the time!)
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 10-21-2011, 05:12 AM   #8
chrisn's Avatar
Rewards Points: 120
Hence my comment
"I use a 2 1/2 for almost everything( although not necessarily a Purdy) "
Old 10-21-2011, 07:12 AM   #9
Net tech, any time you have a color or finish change, paint should be overlapped onto the joining surface. If, of course, both surfaces are being painted. I use flat brushes mostly. The only time I use angle brushes is when I need a point on the brush, which is usually only for window sash and tight detail cutting in. Laying off flat surfaces requires a light-handed, level, even stroke, which means you have to manipulate an angled brush too much to do so. Just my opinion.
Old 10-24-2011, 02:09 PM   #10
Another issue I am running in to is lighting. The room is 12x14 with 10ft ceiling. There are 2 windows in the room, but they don’t pass enough light to eliminate the ceiling entirely so when painting I am leaving bare spots. What would you recommend in that situation?
Old 10-24-2011, 04:01 PM   #11
Another issue I am running in to is lighting. The room is 12x14 with 10ft ceiling. There are 2 windows in the room, but they donít pass enough light to eliminate the ceiling entirely so when painting I am leaving bare spots. What would you recommend in that situation?
???????, Never mind. You mean "illuminate", it dawned on me just prior to submitting. Get a drop light. You might benefit from reading some articles I have on rolling ceilings, at the bottom link of my signature lines. I think you might have some technique issues as well. When I work with limited light, I increase my number of back and forths a bit to be on the safe side.
Old 10-24-2011, 04:27 PM   #12
of course I meant illuminate, sorry.
Yes Joe, I read all of your articles and realized I made a few mistakes. Will go back with a Ĺ inch roller the second time and roll as you explained in your posts.
What wattage work light would you use? The one I was using was not enough to light up the ceiling entirely, I constantly had to move the light.
Old 10-24-2011, 04:45 PM   #13
Thanks. You can buy a cheap contractor's drop light at the big boxes for 10-15 bucks, which usually use 300-500 watt halogen bulb. Worth the price. Sometimes less light/no light is better to roll ceilings as it's hard to see where you're at. Sometimes low light highlights the difference between dry and wet color, where bright light washes the difference out. Try playing around with the light to see what best illuminates your area. It's better to have the light coming from an angle than from directly underneath.
What Size Crown Molding? Jim McClain Interior Decorating 1 10-04-2010 08:16 AM
Crown molding - uneven ceiling jelly Carpentry 9 01-05-2010 07:24 AM
Ceiling Molding BESIDES Crown? Say Flat Stock? Scotsman General DIY Discussions 9 12-07-2009 03:02 PM
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 08:11 AM
Painting Crown Molding Tonya0320 Painting 7 02-27-2008 04:10 PM
