Painting Right After Priming - Painting - DIY Chatroom Home Improvement Forum
Old 04-20-2013, 07:39 PM   #1
Rewards Points: 874
Painting right after priming
Is it okay to paint right after the primer dries?
Mstrlucky74 is offline   Reply With Quote
Old 04-20-2013, 07:43 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
For the most part- yes. Depends on what prolbem the primer is solving though.
For stain killing- better to let it really dry- like overnight - if possible.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 04-21-2013, 02:44 AM   #3
cdaniels's Avatar
Follow the label recommendations.There is good stuff to know on the side of the can.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following 2 Users Say Thank You to cdaniels For This Useful Post:
Gymschu (04-21-2013), ToolSeeker (04-21-2013)
Old 04-21-2013, 03:35 AM   #4
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
If I'm painting metal with spray cans, I just start painting as soon as the primer is no longer wet.
With a brush or roller paint job, if you start painting too soon, the water (in latex paint) or solvents (in oil based paints) can disolve the primer real quick, fast enough that some of the primer starts mixing in with the paint a little and contaminating the brush or roller as you move them over the surface, then it's best to wait a while till the primer is actually dry.
RWolff is offline   Reply With Quote
Old 04-21-2013, 06:58 AM   #5
The Following User Says Thank You to jsheridan For This Useful Post:
Old 04-21-2013, 06:00 PM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
Originally Posted by jsheridan View Post
I read that around 4 am this morning. You will notice my lack of comment.
The Following User Says Thank You to chrisn For This Useful Post:
jsheridan (04-21-2013)
Priming before painting after wallpaper removal question spiceoflife Painting 6 09-11-2011 09:25 AM
priming & painting T&G porch boards GlennW Painting 7 09-07-2009 10:19 PM
Caulking...Priming & Painting with Tape saggdevil Painting 3 05-19-2009 11:42 AM
Priming "builders grade" paint before painting Plasmech Painting 10 03-30-2008 02:37 PM
