Painting Regular SPF Lumber For Weather Exposure - Painting - DIY Chatroom Home Improvement Forum
Old 02-19-2012, 04:23 PM   #1
Rewards Points: 1,062
Question
painting regular SPF lumber for weather exposure
i was wondering if painting regular SPF lumber with outside enamel paint and then protecting it with aluminum flashing will make it weatherproof significantly longer.
i want to build my window frame box of 2x lumber but i'm not supposed to use PT cause PT reacts with aluminum badly, supposedly. as for vinyl lumber, i cannnot seem to find 2x, only 1x (Azek).
thanks
Old 02-19-2012, 09:44 PM   #2
Rewards Points: 388
thanks
Are you wrapping the board in aluminum flashing so that the it's protected from direct sunlight? If so, I think I'd still prime first, then apply an exterior enamel - make sure all 6 sides of each board are completely coated, then countersink nail heads and fill with putty...With that system, yes, it absolutely will "weatherproof" the board significantly longer.
ric knows paint is offline   Reply With Quote
The Following User Says Thank You to ric knows paint For This Useful Post:
amakarevic (02-20-2012)
Old 02-20-2012, 06:06 PM   #3
Wink
Thanks, Rick !!
Tags
weatherproofing
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 10:42 AM
Painting Treated Lumber? cambishop Painting 9 08-04-2011 08:32 AM
painting weathered treated lumber wire_twister Painting 7 10-04-2010 02:08 PM
painting treated lumber queenbee Painting 2 05-12-2010 04:57 AM
pressure treated lumber - Painting Question slim one Painting 1 05-05-2009 06:35 PM
