Old 05-15-2012, 03:14 PM   #1
Painting reclaimed, treated lumber
Last summer I rebuilt my picket fence, using reclaimed 2 x 4s from my old deck for the main horizontal components. These boards were originally treated and stained, and at a later point had been painted. I sanded off the old paint and then primed and painted the boards with a high-quality Valspar exterior paint.
By late January paint had started peeling off the boards, and now they're simply a mess. (The reclaimed pickets, which also had been treated lumber, are doing just fine. The 2 x 4s, for what it's worth, were at least 17 years old, whereas the pickets were about 10-12 years old.)
The main differences that I can think of between the two boards are:
- Age
- The fact the the 2 x 4s had been stained at least once
Before I tackle the 2 x 4s again--and I definitely don't want to have to dismantle the entire fence--I'd like to know if anyone has advice about how to prime the boards so that they don't start peeling again a few months later.
Thanks in advance.
jcreek is offline   Reply With Quote
Old 05-15-2012, 04:17 PM   #2
Gymschu's Avatar
Painting treated lumber is always tricky and really not recommended. The chemicals, etc. in the PT wood are constantly moving through the paint film causing possible peeling issues. We usually stain PT wood if it needs sealed or a color. I would consider staining with a solid color stain. P.S. You really did not say what type of primer and paint you used before. That could be an issue also.
Old 05-15-2012, 05:53 PM   #3
paper hanger and painter
chrisn's Avatar
- Age
Thanks in advance.
I highly doubt that any Valspar paint would be considered "high quality"
Did you also use Valspar primer? latex? oil?
Old 05-16-2012, 09:49 AM   #4
sdsester's Avatar
Use a quality 100 percent acrylic solid stain instead of primer and paint. Sherwin Williams and MAB make products I know best. Lots of factory colors but also tint bases. Stay away from box store stuff.
sdsester is offline   Reply With Quote
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 11:42 AM
Treated lumber secutanudu Painting 5 09-11-2010 12:51 PM
Non treated lumber - base plates... dj1963 Building & Construction 5 06-24-2010 09:42 PM
pressure treated lumber - Painting Question slim one Painting 1 05-05-2009 07:35 PM
Painting Pressure Treated Wood stephen44 Painting 11 04-30-2009 08:27 AM
