Painting Questions - Painting - DIY Chatroom Home Improvement Forum
Old 01-02-2008, 10:35 AM   #1
Painting Questions
Hello, I have a few questions on how to paint my house.
I'm painting a off white room wall with a few spots missing a paint / paint chipped.
1) Do I just cover it with primer (which kind of primer) and then paint over it or do I have to prime the whole wall?
2) It has the texture that comes with new homes, will painting it get rid of it? If so, what kind of paint roller cover should I use to maintain it?
3) For picking the size of the paint roller cover (1/8, 1/4, 3/8, etc...), do you pick according to what surface is already there, or what surface you want to appear?
houseworkman is offline   Reply With Quote
Old 01-02-2008, 11:14 AM   #2
Oldguy
Rehabber's Avatar
Best general use primer is Zinsser bullseye I would use a 3/8" nap roller, (I like lambswool ) and no it won't destroy the texture
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 01-02-2008, 07:48 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
You should be able to "spot prime" jut the spots that need it
2)
There are many textures for new homes, but paint colors, it doesn't fill
Painting should not smooth out any texture
3)
Which size nap to use painting depends on the wall texture type (and size of cracks, popcorn, sand, plaster...)
It has very little to do with how you want the wall texture to appear
If you are referring to paint stipple (the little teeny bumps left by rolling paint), the paint itself has more to do with that than nap length
A good quality paint will have more "leveling characteristics" and leave less "stipple"
Mostly smooth walls could be done with a 3/8" nap, light to medium textures will most likely favor a 1/2"
slickshift is offline   Reply With Quote
Old 01-03-2008, 09:30 PM   #4
Workaholic's Avatar
Rewards Points: 268
Can you get a picture? I am not sure exactly what you mean.
If you are missing good size chips of paint then you will want to fix that prior to painting, as Slick said paint will not fill paint chips.
Sean
Workaholic is offline   Reply With Quote
Garage drywall painting haylo75 Painting 18 11-12-2007 08:13 PM
Painting Exterior Spruce Rough-sawn trim questions Stonemeel Painting 8 09-11-2007 07:00 AM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
A Few Different Questions About Painting Mayzee1 Painting 8 04-24-2007 07:59 AM
Painting exterior of house crebive Painting 2 05-27-2006 11:53 AM
