Painting PVC Trim - Painting - DIY Chatroom Home Improvement Forum
Old 03-30-2011, 10:38 AM   #1
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Painting PVC trim
I'm finishing up a bathroom remodel and was going to put PVC trim around the ceiling but I'm not crazy about the white color. Will PVC trim take paint without peeling? Especially in a humid bathroom?
Any special prep or paint that would make a difference?
Old 03-30-2011, 10:49 AM   #2
I would scuff it with some sandpaper if it's glossy, then apply a coat of BIN pigmented shellac. That'll bond, then finish as you like.
The Following User Says Thank You to jsheridan For This Useful Post:
Blondesense (03-30-2011)
Old 03-30-2011, 12:39 PM   #3
Too Short? Cut it Again!
I would scuff it up too but I would use a primer especially for plastics or even a color of plastic paint if you find one close to what you want. Krylon Fusion comes as a primer and in a myriad of colors and is just for plastic. I think it only comes in spray form. I have used it on outdoor resin and PVC furniture---even a kids play set and it holds up well. Rustoleum makes a plastic primer in liquid and spray form and I have reasonable luck with it too. You can top coat it with whatever you want. Melamine would be my last suggestion but you will probably get nailed for a gallon and it is pricey.
The Following User Says Thank You to user1007 For This Useful Post:
Old 03-30-2011, 03:18 PM   #4
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Scuff it. Apply a quality bonding primer, and paint with a quality 100% acrylic latex. My choice would be SW Bonding primer and SW Pro classic Satin or Duration Satin. They will both last a long time in a bathroom environment
housepaintingny is offline   Reply With Quote
The Following User Says Thank You to housepaintingny For This Useful Post:
A couple questions (edging & trim painting) cellophane Painting 20 01-14-2010 05:23 PM
Painting fireplace & trim? bltwa Interior Decorating 4 03-08-2009 01:57 AM
Spray painting interior trim to look like glass. sprayer48 Painting 2 04-15-2008 07:15 PM
Painting Exterior Spruce Rough-sawn trim questions Stonemeel Painting 8 09-11-2007 07:00 AM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 10:16 PM
