Old 07-13-2014, 08:13 AM   #1
Share |
painting pvc boards ?
are there any issues to know of when painting pvc boards ?
Fix'n it is offline   Reply With Quote
Old 07-13-2014, 08:35 AM   #2
Make sure there clean, a light sanding and use A quality latex paint.
Old 07-13-2014, 09:00 AM   #3
Mod
kwikfishron's Avatar
There can be with dark colors. Azek recommends that you only use paint with a LRV (Light Reflective Value) of 55 or higher. http://en.wikipedia.org/wiki/Light_Reflectance_Value
http://www.azek.com/technical-center/faqs.aspx#qTrim-20
kwikfishron is offline   Reply With Quote
Old 07-13-2014, 09:43 AM   #4
the boards would be new. and the color would not be dark. medium'ish. this would be for trim around windows/doors.
Old 07-13-2014, 09:56 AM   #5
Mod
The LRV should be located on the paint color chip. Make sure you use a 100% acrylic latex paint. No need to prime either.
The Following User Says Thank You to kwikfishron For This Useful Post:
Fix'n it (07-14-2014)
Old 07-14-2014, 08:44 AM   #6
LRV of 55 would be a pastel color. LRV runs from 0 (black) to pure white (99).
Will22 is offline   Reply With Quote
The Following 2 Users Say Thank You to Will22 For This Useful Post:
Fix'n it (07-14-2014), kwikfishron (07-16-2014)
T&G Boards Over Existing Ceiling Earnie Building & Construction 15 01-08-2014 03:07 PM
Painting rough cedar interior walls teri777 Painting 6 06-06-2013 04:21 AM
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 10:42 AM
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 05:52 AM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
