Painting PVC - Painting - DIY Chatroom Home Improvement Forum
Old 04-23-2010, 11:41 AM   #1
Painting PVC
I'm using more and more pvc type trim boards. How should I prep the surface for paint and what paint should I use?
mrgins is offline   Reply With Quote
Old 04-23-2010, 07:48 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
just clean it good and use a high quality acrylic paint
if you want to use a dark color check out the vinyl safe paints from sherwin williams
Tom Struble is offline   Reply With Quote
Old 04-24-2010, 06:16 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Most quality acrylic paints will stick if the trim is clean, clean, clean
Use a cleaner that doesn't leave any residue such as an ammonia-based cleaner or the Azec Approved "Power" brand
Though in my experience I can't deny the superior "sticking power" of BM's "Aura" line on properly prepped "PVC/Plastic/Composite" type trim
"Sticks like glue" as they say....
Not an easy thing on this type of substrate
slickshift is offline   Reply With Quote
Old 04-25-2010, 04:18 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
Duron's Signiture line will " stick like glue" also
Old 04-25-2010, 08:57 AM   #5
the thing with painting pvc is the paint is not ''sucked in'' like paint on wood so it can take quite awhile for the paint to fully cure
painting exterior door JP79ST Painting 18 05-18-2010 04:04 AM
New Member: Painting Contractor Induspray Introductions 3 01-04-2010 07:50 PM
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 05:52 AM
Help! Painting problems on my finished garage mad dog Painting 7 07-23-2009 04:19 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
