Old 04-24-2005, 12:32 PM   #1
Painting a problem wall
The home that we have just purchased has a serious bathroom problem. The previous owners removed wallpaper from the walls but didn't bother to remove all of the old wallpaper paste. They then painted over it (a hideous pepto pink I might add) and now I'm not sure how to proceed with repainting. The walls are plaster to begin with and have their own problems being uneven (really uneven) and I'd like to paint it a periwinkle blue. Any suggestions? I really didn't want to have to get out the palm sander but will do anything to get rid of the old "wallpaper netting" running throughout the walls. Thanks in advance
Cbear1883 is offline   Reply With Quote
Old 04-24-2005, 03:13 PM   #2
Paperhanger/painter
ProWallGuy's Avatar
Either the palm sander, or:
Scrape off any/all loose or peeling paint. Apply a coat of oil-based primer. Make sure it is a heavy-bodied, slow-drying long oil. This product is a good example of one. After thoroughly dry, lightly sand, and skim coat the walls with joint compound until smooth. Prime again with an acrylic primer, preferably tinted close to your finish color. Then topcoat with 2 coats of your finish product.
ProWallGuy
ProWallGuy is offline   Reply With Quote
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Wall Patching Shows Through After Painting wcw5961 Painting 5 11-16-2006 06:33 PM
Exterior brick wall has cracks and moves...is this a huge problem? ConstantChange Building & Construction 3 06-16-2006 10:09 AM
foundation/basement wall problem king45 Building & Construction 1 03-17-2006 06:31 PM
Basement wall Problem dazusa Building & Construction 2 01-20-2005 10:16 AM
