Painting Problem (foto) - Painting - DIY Chatroom Home Improvement Forum
Old 10-26-2009, 10:25 PM   #1
DIY on the budget
diy-diy's Avatar
Question
Painting problem (foto)
While priming wall in the bathroom in some places prime doesn't stick up and comes off on it's own, very few places in fact. Shall I re-do everything or just sand problematic places and prime it again? What's the best course of action?
diy-diy is offline   Reply With Quote
Old 10-27-2009, 04:50 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 496
What was the primer and what and where were you painting?
More info is needed
Old 10-27-2009, 08:09 AM   #3
DIY on the budget
diy-diy's Avatar
More info is needed
It's in the bathroom, on top of old paint (not sure what's was old paint, it's at least 5yr. old). Using acrylic latex primer.
Old 10-27-2009, 04:32 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
That sure looks like a few layers of paint coming up. It would have done that with just about anything you put on the wall. Scrape any loose area's, patch and prime and then paint as usual.
Old 11-08-2009, 10:35 PM   #5
i had a similar problem. Use an oil base primer, that will hopefully solve your problem.
bdog is offline   Reply With Quote
window sash painting problem nerd_flanders Painting 1 08-18-2009 08:47 AM
Problem Painting Ceiling! Please Help! p00lbys Painting 3 06-06-2009 04:59 PM
Painting DensShield tile backer board warriorfox Painting 2 05-15-2008 04:08 PM
Painting over a sponge painted wall Snowdog Painting 3 03-16-2008 11:13 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
