Painting Pre-primed Doors - Painting - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 01:26 PM   #1
painting pre-primed doors
I thought the store primer was enough, but I am using a small sponge roller and getting streaks. Do I need to prime their primer? and how do I get rid of streaks now that I have two coats of semi gloss paint on it?
I have only done one door and I am not happy with the way it looks. Most of it is nice and smooth but there are some streaks??
Trish2 is offline   Reply With Quote
Old 02-21-2012, 01:47 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Look at a thread lower in the page called painting interior doors- pretty much answers the same Q.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 02-21-2012, 04:37 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
If you have a lot of doors, consider renting a sprayer.
Much better results.
titanoman is offline   Reply With Quote
Old 02-21-2012, 04:56 PM   #4
BraniksPainting's Avatar
Trish,
I don't use sponge rollers for painting latex on doors. I use a small 4" Whizz type roller w/fabric roller cover. One reason I use a fabric roller is because it holds a lot of paint and I can spread it around. Foam hold barely any paint and has a tendency to dry quickly for that reason.
I'm not sure what type of doors you have so it's hard to tell you the technique I like to use when finishing doors.
BraniksPainting is offline   Reply With Quote
Old 02-21-2012, 06:10 PM   #5
Sure!
Old 02-21-2012, 07:14 PM   #6
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
A sprayer is not always the most efficient way to go. Especially for a diyer. If your inexperienced with a sprayer and spraying doors you can end up having a lot of runs and sags. Even as a pro painter their are only certain situations that warrant breaking out a sprayer for some doors. With the right technique and proper tools you can get a nice smooth uniform finish on doors by hand, even on metal doors.
housepaintingny is offline   Reply With Quote
Old 02-21-2012, 07:15 PM   #7
Disabled wood vet
titanoman's Avatar
You're right. A sprayer needs to be in good hands.
Old 02-21-2012, 07:16 PM   #8
Rewards Points: 616
Originally Posted by BraniksPainting View Post
Trish,
In general we use a mini fabric roller too, as you said it holds more paint and then tip it off with a brush. That is also how we train our guys, as its pretty efficient. I have found sponge rollers to be pretty much useless.
Old 02-22-2012, 12:39 PM   #9
Old 02-22-2012, 06:39 PM   #10
Thank-you
I want to thank all for their suggestions. I went and got the better rollers and that has help a lot; I also got primer for the other 3 doors so that I do not have to put so many coats of my semi gloss. The door I started has been fixed and looks good
Old 02-22-2012, 07:26 PM   #11
Too Short? Cut it Again!
Also remember it takes latex/acrylic paints 30 days to cure and you cannot judge the appearance of the surface completely until then. Many imperfections will work themselves out in the process.
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 07:42 AM
Painting Interior Doors behrend Painting 1 06-23-2010 11:56 AM
painting metal doors pjm Painting 5 06-04-2008 10:55 AM
painting side by side front steel doors old salt Painting 3 06-04-2008 09:18 AM
Painting over polyurethane coated wood doors flashme18 Painting 9 04-19-2008 10:51 PM
