Painting A "powder Room" - Painting - DIY Chatroom Home Improvement Forum
Old 01-27-2013, 05:30 PM   #1
analogmusicman's Avatar
Rewards Points: 560
painting a "powder room"
I've always used enamel paint for bathrooms (and kitchens). is this still necessary for a "powder room"?
tnx,
analogmusicman is offline   Reply With Quote
Old 01-27-2013, 05:34 PM   #2
Rewards Points: 13,712
Nope, but it would hold up better to cleaning.
Old 01-27-2013, 05:39 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
What do you mean by enamel?
Kind of an antiquated term-- but i would suggest an eggshell finish for a bath/ powder.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Gymschu (01-27-2013)
Old 01-27-2013, 06:44 PM   #4
Rewards Points: 560
I don't thhink "enemel" is such an antiquated term. there's regular interior paint and then there's enamel when toughness (or water-resistance) is required.
tnx,
Old 01-27-2013, 06:51 PM   #5
Nothing old about that term.
http://www.sherwin-williams.com/sear...on=&Ntt=Enamel
I've used it many times.
Old 01-27-2013, 07:14 PM   #6
tnx,
So is any semi gloss also an enamel? And if not, why?
Enamel these days seems to be applied to anything above a flat.
And those things being labeled enamel have all sorts of degrees of hardness.
But that is beside your question- use something with some sheen. Call it enamel. Many do.
Old 01-27-2013, 07:41 PM   #7
Enamel meams "hard surface paint." Nothing to do with the sheen.
It can be bought in several differant sheens, also can be oil or water based.
Old 01-27-2013, 07:54 PM   #8
So he should use an eggshell for his powder. I would . Works great.
Is Regal Select eggshell an enamel?
I know painters that use Regal semi on trim. is it an enamel?
I think WB Impervo is kind of soft- even after cure. Is it an enamel?
I like Muralo WB Ultra Semi. I think it's an enamel...
Zinnser 123 primer is really hard when cured. is it an enamel?
The definition is a hold over from when oils ( yes, ones with sheens) dried and cured really hard. Some WB approach that, but not many.
Most of the paints on your list were baked on specialty finishes.
Not going to argue the point, because even I use the term, but it is VERY loosely defined.
Old 01-28-2013, 05:06 AM   #9
paper hanger and painter
chrisn's Avatar
Rewards Points: 392
better watch out, you know who might be reading this
Old 01-28-2013, 06:16 AM   #10
I think the one thing we've learned in the biz is that there is a ton of variation, from brand to brand, and even within the same brand. As applicators we don't necessarily need to understand the chemistry, but we do need to know what each product can and can't do and how to achieve the look and meet the needs of our customers. That comes from knowing the range of products available, experience. We can't just trust the paint companies, not so much because they deceive, but more so because of interpretation.
As to enamel, I try to keep it simple. I consider enamel any film forming coating that forms an elastic "skin". It may not pass a paint chemist's muster, but it works for me. I have my go to finishes that I use mostly, but have some understanding of different products and where they might be required or a better choice. Just as flats, etc, have a range of sheens, semi-glosses, etc, have a range of hardness. So to BJ, yes, all of those finishes that you mentioned I would consider enamels, but not 123 which is not a topcoat.
Old 01-28-2013, 04:33 PM   #11
chrisn's Avatar
Rewards Points: 392
for most of us
Old 01-28-2013, 05:22 PM   #12
Rewards Points: 4,796
Not to mention "flat enamel".
jeffnc is offline   Reply With Quote
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 10:42 AM
painting exterior door JP79ST Painting 18 05-18-2010 04:04 AM
painting my mom house supaflyz Painting 5 07-28-2009 02:34 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
