Painting Porch Rockers - Painting - DIY Chatroom Home Improvement Forum
Old 08-27-2014, 06:47 PM   #1
Rewards Points: 436
Painting porch rockers
Of which we have five! Currently white, some type of what appears to be a baked on finish, no chipping, flaking, or whatever but they are white and the finish has been discolored by what appears to be black mold. I've washed with the usual things like tsp, etc., bleached with Clorox etc, and no joy. So the wife wants them painted a different color. Suggestions as to how to prepare the surface withOUT using stripper and also as to paint and primer welcome. Ron
ront02769 is offline   Reply With Quote
Old 08-27-2014, 07:23 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,820
Can you tell if it is a surface contaniment....
I do have some discoloration on powder coated (sounds like yours) from pine trees etc.
You said you've tried TSP etc.... have you used solvents... acetone.. laquer thinner...???
MTN REMODEL LLC is offline   Reply With Quote
Old 08-27-2014, 07:41 PM   #3
Gymschu's Avatar
Rewards Points: 838
Marinate them in a good cleaner, something like Krud Kutter, the Boss, Simple Green. Put them in a shady area. Wet them with your garden hose. Load up a garden pump sprayer with some diluted cleaner (like the ones listed) and spray/douse them with the contents of the sprayer. Keep pumping the cleaner on them every 5 - 10 minutes or when the cleaner looks like it's beginning to dry. Use a nylon brush on the stubborn stains. The diluted cleaner will remove lots of the krud without elbow grease. Then pressure wash them with gentle pressure, something in the 1500 psi range being careful not to damage the surface. If they are metal, you won't have to worry so much about damaging the surface, like you would have to with wooden rockers.
This method has yet to fail me in 35 years.
Old 08-27-2014, 08:06 PM   #4
Rewards Points: 436
My bad on the description, they are wood. And it is not pine tar, whatever since they sit undercover...and we don't have any pines nearby. And it appears to be not ON the surface....but IN it. Ron
Old 08-28-2014, 07:33 AM   #5
Gymschu's Avatar
Rewards Points: 838
Just sounds like mold or mildew which comes in many forms. It can be black, green, dark green, etc. The black mold that takes hold on wood is feasting on the organic material on/in the wood such as paint, sealer, toner, etc. Yes it basically is embedded in the wood. That kind usually takes some aggressive scrubbing to loosen its' grip. Like I said, as a painter, I've had to deal with mold and mildew for 35 years and I can't recall a time where I couldn't get it off using my "marinade" of cleaners. Sometimes it can be a battle, but, something like Krud Kutter kills the mold and the spores thus stopping the continued growth.
Front Porch - Repair or Completely Replace? DIYerIT Building & Construction 1 05-26-2011 12:58 AM
Porch painting naf0 Painting 1 09-12-2010 03:33 PM
Painting concrete porch with many paint layers underneath normjennifer91 Painting 1 07-13-2009 07:18 AM
Painting square porch columns katie74 Painting 2 05-13-2009 12:37 PM
Painting exterior porch floors mlupa Painting 2 03-17-2009 04:02 PM
