#1 |
DIY'er listening to PROS!
Painting Porch Drywall Ceiling
Hello,
Let me start by thanking you guys for any advice/help. Original Paint Job/House built: 1993 in Richmond, Va. OK, I'm finally going to get to this. I should have done it last year! I've got the ole (cheap??) drywall ceiling on my front porch. I don't know what kind of sheet was used. The porch roof is vented at the soffit and where the shingles meet the siding. There are a few joints where the tape has started to curl. Not bad, especially after all these years. The putty under the tape seems to be the culprit. I have just started to remove some of the tape and thought that I need help. What is the best way to hide the seams? The sheets are in good shape. I would rather put plyboard up but don't have the time right now. Should I putty and tape or is there a better way to handle this? Thanks! Chris |
#2 |
Lic. Builder/GC/Remodeler
My first thought is: Is the sheetrock and compound used for exterior application? ....There are different products for such an exterior area.
If not, it doesn't matter what you do, it will all peel off again....
- Build Well - |
#3 |
Thanks, Build Well. Yep, that's one of the problems. I don't know what was used when they built this house and if I don't looks like I should find the time to redo it!
Chris |
#4 | |
Painting Porch Drywall CeilingQuote:
Once it is done, apply the proper primer/sealer (paint) and proper kind of exterior top coat paint over the new work.
- Build Well - |
#5 | |
Chris |
| Display Modes | |
| Garage drywall painting | haylo75 | Painting | 18 | 11-12-2007 09:13 PM |
| Drywall Garage Ceiling Recommendations | jsjames | Building & Construction | 6 | 08-22-2007 04:47 PM |
| Drywall Painting Question | WorkOnIt | Painting | 8 | 06-14-2007 05:12 PM |
| Drywall thickness on ceiling question. | Doug Crf | Building & Construction | 3 | 08-28-2006 06:47 AM |
| Basement Ceiling- Combo of Drywall and Drop ceiling? | H Thomas | Building & Construction | 5 | 03-27-2006 09:27 AM |
