Painting A Popcorn Ceiling - Painting - DIY Chatroom Home Improvement Forum
Old 01-13-2013, 07:20 PM   #1
Painting a popcorn ceiling
I just put a coat of oil base primer on my popcorn ceiling today. It came out great. In a few days I'm going to put a coat of ceiling paint on. Is it ok now to use a latex paint? I hope so. That oil base stuff stunk up my house and is nasty to clean up. Thanks!
larrh7 is offline   Reply With Quote
Old 01-13-2013, 07:31 PM   #2
cdaniels's Avatar
Probably so....what primer did you use? Are you planning on two coats of finish paint?
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 01-13-2013, 07:53 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
Was so good you made 2 threads that said the same thing! WTG!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Gymschu (01-14-2013)
Old 01-19-2013, 08:46 AM   #4
Rewards Points: 874
Larh... I have a popcorn ceiling that needs to be repainted. Should I first use an OIL based primer and why? Thanks a lot.
Mstrlucky74 is offline   Reply With Quote
Old 01-19-2013, 09:56 AM   #5
Rewards Points: 5,974
I guess there is some confusion because there are 2 threads. Lucky you need to use an oil primer or Gardz primer unless the popcorn has already been painted before. Water is what we use to remove popcorn so if you use a water-based primer the popcorn will come loose and start coming off.
Best roller to use with B-I-N on Popcorn Ceiling? AlaskaChick Painting 12 07-01-2012 11:38 AM
Does a newly skimcoated ceiling need painting? clubjuggler Painting 14 11-20-2009 04:09 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
scraped the popcorn off the ceiling, and tore through the paper-now what chapito Painting 6 07-18-2008 11:17 PM
Question about popcorn ceiling J187 Building & Construction 4 06-30-2006 02:33 PM
