Painting Polyurethane Over Latex Paint - Painting - DIY Chatroom Home Improvement Forum
Old 04-09-2011, 08:10 PM   #1
painting polyurethane over latex paint
If I paint polyurethane stripes over latex paint for a shimmery look, what happens when I want to paint over it???
racy is offline   Reply With Quote
Old 04-09-2011, 10:13 PM   #2
Rewards Points: 256
Hey racy,
No problem, give the urethane a light sand to scuff it up, PRIME using a good quality vinyl primer and repaint. That simple.
Best of Luck
Steve
spraygunn is offline   Reply With Quote
Old 04-09-2011, 11:58 PM   #3
Faron79's Avatar
Rewards Points: 260
Make sure you use a Water-based Poly over Latex paint.
Oil-Polys are fairly amber.
Water-Polys are clear.
Also...when painting over:
* You'll have to feather-sand all the "stripe-ridges".
* If you don't, you'll always see the profile of those stripes.
* You MAY also still see their profile...even if you do sand all the edges, since there's a different thickness where the stripes are.
* They won't be visible straight-on typically, but at some angles, you may see them.
Faron
Faron79 is offline   Reply With Quote
Old 04-10-2011, 02:03 AM   #4
Plus oil based poly are brittle, it can crack on latex.
StevenH is offline   Reply With Quote
Oil based paint over Latex? No need for Primer? Jasonuncloned Painting 2 10-20-2010 11:33 PM
latex paint over oil-based = peeling paint! help! ImaDIYnewbie Painting 5 09-20-2010 05:48 PM
Questions about painting and possibly adding siding to stucco house? krm27 Painting 3 01-19-2010 01:22 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
