Old 05-01-2012, 05:25 PM   #1
Painting Plywood
Previous HO used Plywood for Door Jambs. Coated them with a thin layer of mud, and then paint. Due to expansion, contraction, the paint was cracking. All Linear ..
I have gone aheaded and sanded it all down. There are some dents I will need to bondo on and sand smooth. I plan to just prime with Xim Peelbond (1x or 2X) and then paint ontop.
Will the paint hold over time or will I still experience the cracking due to different expansion/contraction rates ?
It's my understanding that this is more ~highlighted~ as it's not solid wood, but plywood....
mobiledynamics is offline   Reply With Quote
Old 05-01-2012, 06:06 PM   #2
paper hanger and painter
chrisn's Avatar
Painting Plywood
Would'nt it be easier, better, to replace with real wood ones?
Old 05-01-2012, 06:09 PM   #3
Painting Plywood
Not really. The jambs are screw ....rock is mudded flush to it.
The style is caseless doors with Frye Reglet Revel to it.
Old 05-01-2012, 06:45 PM   #4
Painting Plywood
What a mess.
Post a picture. To me any of your terms made no since.
Plywood is great, but not for jambs. It leaves the end of the plywood exposed.
Trying to apply mud over plywood is sure to fail.
Old 05-03-2012, 06:21 PM   #5
Mr. Paint's Avatar
Painting Plywood
In answer to your question, Peel Bond Primer is excellent in expanding/contracting environments. Be sure your topcoat is satin or semi-gloss, 100% Acrylic that will have the same coefficient of movement.
Personally, it sounds like an architectural nightmare that I would rip to the studs, insulate and re-wire as needed and start all over.
Good luck!
Mr. Paint is offline   Reply With Quote
Painting exterior plywood wall sheathing hiphi45 Building & Construction 2 12-24-2011 01:12 PM
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 11:42 AM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-14-2010 12:09 AM
It is hard to find 1/2 t and G plywood so would regular plywood be ok ? dewi Flooring 14 05-04-2010 01:05 PM
cutting plywood panels w circular saw Klawman Carpentry 11 12-11-2009 02:40 PM
