Old 04-25-2010, 12:34 PM   #1
Painting a pitted concete surface
I've started painting the interior bare concrete block walls of a large garage, with 600 SF of wall space. The blocks are heavy and hard, made around 1950. Each block has 50-100 pits on its surface, varying from pinhole to the size of a large nail hole. This appears to be the way the blocks were made.
I painted a test patch. Two coats of quality block filler, applied with a 1.25 inch nap roller, covered only some of the holes. A coat of paint put on with the same roller covered a few more, but the pits, even when paint has gotten into them, cast shadows that look like black spots across the surface of each block. I think many are just too wide and too deep for the block filler to work.
I tried spraying with an HVLP which didn't really help.
Applying paint with a thick brush does the best job at covering the pits, but I'm not anxious to paint 600 SF, both primer and paint, with a brush.
Any ideas?
Thanks.
dave11 is offline   Reply With Quote
Old 04-25-2010, 02:02 PM   #2
Having experienced that a time or two, I chose to go with a skim coat of mortar to fill all the holes. Then it was easy to spray with an airless.
Shamus
Shamus is offline   Reply With Quote
Old 04-25-2010, 07:29 PM   #3
I guess I associate mortar with softness. Did you mean a skim coat of concrete?
Either way, it sounds like a lot of effort and money for just my garage. If there's no other trick to try, I guess I'll just live with the pitting.
Painting a Banquet Table (Melamine Surface) jessi1 Painting 4 10-14-2011 03:57 PM
painting exterior door JP79ST Painting 18 05-18-2010 05:04 AM
Please see picture - How to hide surface imperfections before painting seth Painting 1 03-25-2009 03:19 PM
Another name for surface wiring/wire-mold? fw2007 Electrical 4 01-09-2008 05:56 PM
