Painting A Pergola With Treated Lumber - Painting - DIY Chatroom Home Improvement Forum
Old 05-08-2013, 03:38 PM   #1
Painting a pergola with treated lumber
I know (thanks, Sherwin Williams) now to use an oil-based primer before applying latex paint. My question is can I paint an anti fungal preprimer or do I have to clean it first?
Drinkinhand is offline   Reply With Quote
Old 05-08-2013, 03:59 PM   #2
Too Short? Cut it Again!
Hold the phone. Is this this treated lumber yet paintable or stainable with anything? With most, you need to let it sit for six months at least. Some can be treated right away but if you do not have treated lumber that can be painted or stained you will be creating a horrible mess. With anything you apply!!!
Why did SW tell you to use primer and paint instead of their solid stain product? Makes no sense to me. I think you got a SW corporate employee green behind the ears. Go back and ask again. Someone has you headed down the wrong path here.
I guess I can understand the recommendation to use a solvent based primer that leaves an alkyd film, and then paint over with acrylic whatever. Just seems like you got bad advice in general here though. Sorry.
Old 05-08-2013, 04:05 PM   #3
Rewards Points: 14,300
No way would I ever paint pressure treated lumber!!
Unless your really into sanding and having to redo it every year.
Low as I would go is waiting until it's dryed out and using soild stain.
Gymschu (05-08-2013)
Old 05-08-2013, 04:10 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 612
He's back
The Following 3 Users Say Thank You to chrisn For This Useful Post:
Drinkinhand (05-08-2013), Gymschu (05-08-2013), jsheridan (05-08-2013)
Old 05-08-2013, 04:15 PM   #5
Jeeze Joe, we almost missed you too! Would you like to go back an edit your recent post?
Treated lumber gets stained or primed and painted all the time. Of course some you cannot finish right away. Suggesting properly aged treated lubmber or timbers will need anymore stain, primer, paint or attention---for that matter---than any other properly prepped primed/painted or transparent/semi-solid/solid stained wood on a regular basis---like annualy---just ain't not gunna fly as sound advice or informed comment.
Actually, if it were me. I would clad the whole thing in stretch vinyl and never have to worry about painting or staining it again. You stretch the membranes over it, top and bottom and take a giant space heater to it to sort of shrink wrap it into place. Or 20-30 hairdryers.
Old 05-08-2013, 06:08 PM   #6
Talking
Painting a pergola
What happened is I painted it the same as the house color. Paint got stained from trees, so I sanded and repainted. Now, between the trees and intense Tennessee sun,it looks like crap again. Now what? Note: the pergola is about 8 years old and was "natural" for at least 3 of those years before I painted it. Looks great for a while but by fall paint looks very thin. I have repainted every spring and this is getting old!
Old 05-08-2013, 06:42 PM   #7
Post a picture of it.
The Following 2 Users Say Thank You to jsheridan For This Useful Post:
Gymschu (05-08-2013), user1007 (05-09-2013)
Old 05-09-2013, 04:12 AM   #8
chrisn's Avatar
Rewards Points: 612
you tell em Joe,
ahh, I mean the other Joe
Old 05-09-2013, 07:14 AM   #9
Trees that drop leaves, flowers, or even nearly unoticeable "fruit" with natural dyes in them can really create problems with paint. I am not sure I know a stock answer for how to resist such natural dye stains.
It would help you could tell us what you used for paint. And to confirm, the paint is not actually failing but is absorbing the dye color from the plant material right?
What kind of tree is it by the way? There are some species you can neuter with an annual spray so they do not produce fruit. That may be the solution to your problem long term.
Old 05-10-2013, 12:05 AM   #10
Originally Posted by chrisn View Post
you tell em Joe,
I get confused too. I sort it out in my mind with these equally great music performances.
Old 05-10-2013, 03:06 AM   #11
chrisn's Avatar
Rewards Points: 612
good one you are on a roll
should be in bed
Painting Pressure Treated Wood stephen44 Painting 14 05-14-2016 08:22 AM
One yr. old pressure treated wood pergola turning green lamm Painting 2 09-21-2012 10:00 AM
Painting Treated Lumber? cambishop Painting 9 08-04-2011 08:32 AM
pressure treated lumber - Painting Question slim one Painting 1 05-05-2009 06:35 PM
